Question about Adaptec (OP-CDRI-LIT-CDDVD) CD-RW/DVD-ROM (Combo) Burner
Adaptec Burner Problem
My Drive won't open. And when I try to open file to create cd it either freezes my computer or just stops responding at all.
  • 57 Answers
If you have a cd in there you can manually get it by using a paperclip and inserting it into the small hole in the front of the drive. It may be possible that your drives are not receiving any power. Are any of the LEDs at the front of your drive on at any time? If not, then it is almost certain that your drives have become disconnected from your motherboard. If this is the case, just open up your computer and make sure that there are at least 2 cables going to each of your drives and that the power cable (which should have white ends with 4 pins) is indeed connected to your drive on one end and your power supply on the other end. Dont forget to check your Bios and try the drivers for an update.
Posted on Sep 12, 2007
Produplicator 1 BD 10x burner causing system to stop responding on Windows 7 64 bit OS
The peripheral is bogus. When one goes bad it is not uncommon for the computer to lock up and freeze Remove the offender and all is copacetic.
Almost sure that the hard drive has gone belly up.
Mar 21, 2017 | Produplicator com Produplicator 7 BD 10X...
Need install cd burner in windows xp
IDE or SATA connections ??????
To enable CD burning for your computer is a relatively simple process in Windows XP.
All you need is a CD burner drive installed in your computer, the disk with the drivers and software that goes with it and an XP-loaded personal computer.
Once your driver is installed, the process is almost automatic.
Here are the steps you should follow to begin creating your own CDs.
Check your system requirements before installing the CD burner and make sure that your system can handle the speed and memory requirements of the drive.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Turn off the computer, disconnect the power cord and remove the cover from the case.
Check the IDE cables inside your computer.
You may be able to connect the optical CD drive to the same ribbon cable as the hard drive if it is set up as a secondary or slave drive or to a separate ATA/IDE channel by a second cable.
Find an empty CD drive slot, remove the plastic cover from the outside, slide the drive in through the back and screw it in place.
If you are using a SATA CD burner, you'll need to connect the red SATA cable from the CD drive to the SATA connection on the motherboard or on your SATA drive controller card.
With SATA drives, you don't have to fool with jumpers.
Attach one end of the separate ATA/IDE cable to the motherboard if you have an IDE drive and the other to the back of the CD burner.
If slaving the drive, hook the drive to the second connection on the main hard drive cable to the burner drive.
If you do that, you'll have to set the jumpers on the CD drive to the "slave" position.
The drive's installation instructions will show you where the jumper pins are and how to set them to the slave position.
If using a separate IDE cable, just leave the jumpers in the factory setting.
If this is an older drive, you may have an analog audio cable as well that connects to the motherboard.
Follow the installation instructions for hooking it up.
Close the case and reconnect the power cord and other cables.
Turn on the computer and let it boot up.
Open the "My Computer" folder and make sure there is a new icon for the drive that you just installed.
XP will generally recognize it automatically, but if it doesn't you'll have to reboot the computer and open the CMOS setup program.
Follow the instructions for your particular PC to open the CMOS window.
Check the ATA channels to make sure both are enabled in setup and that, if you are using a master/slave setup, that the CMOS selections match that setup.
Reboot the system.
If the CMOS settings are correct, the XP operating system will set your drive so that it uses either digital CD playback (no audio cable) or analog playback (with audio cable). To check, open the "My Computer" window, choose "Properties" then "Hardware" then "Device Manager".
You'll see a "DVD/CD-ROM Drives" icon.
Click the plus sign next to DVD/CD-ROM Drives folder.
Click it, then right-click the icon for the new CD burner drive.
Now choose "Properties".
If you don't have an audio cable, left click on the selection box for "Enable digital CD audio for this CD-ROM device".
Insert the CD burner software disk that came with your CD burner.
Insert the disk that came with the drive into the CD drive and install the software following the prompts.
If the drive doesn't come with CD burner software, Windows XP comes with a lite version of Roxio's Easy CD Creator that detects blank CDs.
Just insert a blank CD in the burner and XP offers you a "burn CD" option when you have autoplay set up for the CD-drive.
There are lots of freeware burning software on the internet.
Burn audio, video, and data CDs/DVDs and create and burn ISO files.
Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner.
nero 8.1 essentials free
This is the newest version of the most known CD and DVD burning software, but now with the capability to burn HD DVDs, and Blu-ray Discs
Nero 9 .4.12 free Create, rip, copy, burn, edit, share, and upload online
Nov 10, 2013 | Broderbund Computers & Internet
Download it
Find the location of adaptec easy cd program on your computer
Click start type in easy cd creator then press enter this will display anything associated with the program navigate to the program itself usually located in the program files
then burn it to a cd or dvd software update
also there are lots of freeware nero burning programs on the internet Burn audio, video, and data CDs/DVDs and create and burn ISO files. Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner. nero 8.1 essentials free This is the newest version of the most known CD and DVD burning software, but now with the capability to burn HD DVDs, and Blu-ray Discs Nero 9 .4.12 free Create, rip, copy, burn, edit, share, and upload online Multi-disc file backup and restore on CDs, DVDs and Blu-ray discs; create compressed backup archives with powerful password protection; split archives automatically across multiple CDs, DVDs or Blu-ray discs; restore archive contents to their original locations; integrated Audio CD ripper store your audio tracks as WMA or WAV files Hope this helps.
Dec 20, 2012 | Adaptec Easy CD Creator 3.5 Full Version...
The x box says system update stopped..what has happened? how do i fix it?
Came across a link that might be of some use to you, here's what it says:
Get Updates for Your Xbox 360 Console There are three ways to get updates for your Xbox 360 console:
Update through Xbox LIVE. Copy update to a USB Flash Drive. Burn a DVD or CD. Update through Xbox LIVE
Getting the update free on Xbox LIVE is the best option because your console will be automatically updated as new system software is released.
To update your Xbox 360 console on Xbox LIVE, you must have an Xbox LIVE account with either a Gold or Silver membership, and a broadband Ethernet connection.
To update on Xbox LIVE: Connect your Xbox 360 console to your broadband connection. If your console is not connected already, see Connect to Xbox LIVE. Note Your console will be restarted when you join Xbox LIVE, so be sure to save your game progress. Create an Xbox LIVE membership or add one to your offline profile, if you haven't already. Go to the Marketplace area of the Xbox Dashboard and select Join Xbox LIVE. Follow the steps for creating a profile. You can also add an Xbox LIVE membership to an existing profile by selecting Join LIVE from the Xbox LIVE area of the Xbox Dashboard. You may be asked to update the software on your console. Select Yes and wait for the update to finish. Future updates will be installed automatically, as long as you are signed into Xbox LIVE. Copy the Update to a USB Flash Drive
If you don't have an Xbox LIVE account or have a slow Internet connection, using a USB flash drive is a good option.
Note: The USB flash drive must use the FAT32 file system.
Update using a USB flash drive:
Connect your USB flash drive to a USB port on your computer. Click here to begin downloading the update folder. Save it as "$" anywhere on your computer. Unzip the File. Copy the contents from the unzipped folder onto the root of your flash drive. Safely remove the flash drive from your computer and plug it into a USB port on your Xbox 360 console. If your console is on, turn it off, then back on. The update program will start automatically. Select Yes, update now. When you see the new dashboard, you're done. Burn a DVD or CD
Your other option is to download a file from and burn a DVD or CD. Use this method if you don't have your console connected to broadband, or if you use a dialup connection to the Internet. You could even do this at a friend's house who has a broadband Internet connection and a DVD or CD burner.
To create an update disc you need the following:
A DVD or CD burner. A blank, writeable DVD or CD. The update file from This procedure involves burning the DVD or CD by using Microsoft Windows DVD or CD burning software. If you're using third-party CD/DVD writing software, follow the instructions for creating a data disc.
The same steps apply whether burning a CD or a DVD.
To create a DVD or CD:
Click here to begin downloading the update folder. Save it as "$" anywhere on your computer. Place a blank disc in your burner. From Windows Explorer, select Open Writable CD Folder Using Windows Explorer or open the CD drive icon. Open (double click) the zipped $ folder and drag the contents of the zipped folder to the root of the CD Folder. If the CD write window doesn't open by default, drag and drop the folder onto the CD/DVD RW drive. Note If you are using an earlier version of Windows you will need to open the file using a separate utility (for example, WinZip). In the Explorer window, click Write files to CD from the CD writing tasks or right-click the CD/DVD RW drive and select Write these files to CD. Caution The update filename and folder structure must be intact for the update to run properly. Follow the steps in the CD wizard. When you are finished with the wizard, the CD will eject. Your CD is ready. To update the console:
Place the CD in the Xbox 360 console.
Power cycle the Xbox 360 console. The update program will start automatically. Select Yes, update now and press A. Wait for the update to complete. When the console reboots, you're done. If this does not work then you need to sand your xbox in to microsoft.
Keep Checking Daily for the new update.
Jan 01, 2011 | Microsoft Xbox 360 Console
Hi I want to create a system restore cd for my Toshiba laptop model A105 S2051 its a satellite. I really dont know how to create it since when I bought the system I sorta forgot to create it then. Would...
Go to Start, Programs or All Programs (depending on your OS), then Accessories, System Tools, and click Backup.
A Wizard welcome screen will open. In this screen, click the underlined words for the advanced mode. This will open a tabbed screen. On the Welcome tab, choose the Automated System Recovery Wizard. Another Wizard will open. At this screen, click the "Next" button.
Insert the CD into your CD-burning drive. Double-check the file path and make sure the computer correctly searches for the CD burner. If it does not, click the "Browse" button, find the burner and click "OK." Once the correct path is in, press "Next." At the final screen, click "Finish." This begins the process of creating your restore CD.
Dec 13, 2010 | Toshiba Sattelite A105-S2051 Notebook
My Iomega CDRW64001 keeps ejecting my blank CDs. The external LED blinks for several minutes and then ejects the CD with or without a burn program open. It plays recorded CDs and I'm able to install...
Your best solution (since your USB devices and your network-adapter are not working) is to remove the disk-drive from the old computer, and temporarily connect it as a "slave" disk-drive in the new computer, and then copy all your files from "old" to "new".
Or, try a different brand of "blank" CD-R disks -- the "firmware" (software inside the CD-writer) may not be recognizing "newly-manufactured" media). Unless you can update the firmware (by downloading the latest firmware on another computer, and burning a CD-R disk, and then taking that disk to your computer), it's easiest to "move" the disk-drive to the new computer.
Jul 16, 2010 | Iomega (32885) CD-RW Burner
My dvd drive does not open or responds green light
hello, here is the simplest thing to do if your cd/dvd is stacked inside. 1. punch through the hole infront of your burner using a paper clip, that will force the cd door to open, try it..
Nov 25, 2009 | Pioneer DVR-107D DVD±RW Burner
Need GameBridge to install on a computer without a cd drive.
You need to utilize a program that will allow you to create an ISO copy of the CD to the thumbdrive. When you do this all the files on the USB should be removed BEFORE the copy.
Jul 25, 2009 | Adaptec GameBridge AVC-1400 (2179900)...
Recorded Voice to CD Burner (Want to make CD of voice)
You should be able to burn them directly. Put a blank CD into your CD burner and then pull up My Computer. You should see the CD there in whatever drive you have your CD player/burner set up in (usually D: ). Double click on it to open it. There should not be anything in that folder.
Then while leaving that folder open, go back to My Computer in a new window and open up the folder where you created your sound files (My Documents/My Music). Select the files you want burned to the CD (you can select more than one at a time with by holding down CTRL while you click), right click on them and select 'Copy'.
Then head back over to your blank folder of the CD contents. Right-click and Paste them into that folder. Depending on your version of Windows, either a bubble will pop up on your task bar saying you have files waiting to be burned on the CD or you might have to go into File to find an option to burn to the CD.
Then your files should be all set!
Dec 23, 2008 | Audio Players & Recorders
Cd burner
What programs can I use to burn or create CD's on my computer? If you're running version 10 or higher and have a CD/DVD burner drive installed in your computer you can create audio CDs using it.
Computer DVD Support
CH000885, CD or other disc tray does not close or opens by itself. CH000901, My CD or DVD is skipping. CH001014, Can a DVD burner also burn a CD?
What hardware do you recommend or what is the best? What type of burner, CD-ROM, computer, DVD, fan, hard disk drive, monitor, motherboard, mouse, printer, sound card, speakers, and/or video card does.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner creates reflective sections on the CD causing the computer's CD-ROM laser to.
Good Luck, Read and follow instructions.Please dont for get to Vote/Thank You.
Dec 23, 2007 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
Top Adaptec Computers & Internet Experts
Rommel Balcita
Martin Murray
Robert Graf
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
