Question about Canon PowerShot A75 Digital Camera
MEMORY CARD ERROR READ
My camera is not reading the memory card. I cannot take pictures, nor can I preview the ones that I took. However it will read the other memory card just fine... Can I retrieve the photos taken and if so how?
  • Anonymous Dec 22, 2007
    cannot open pictures because of card error display
    Genius:
  • 2,985 Answers
The memory card that has failed- do you have access to a card reader for the computer? If not we will try to use the camera. Download from www.konvar .com - PC Inspector. This is a recovery program install it and follow the prompts to locate the card in reader or camera will show on the computer a new drive. Then allow the camera to scan the card and you to select where any recovered images to go.
Posted on Sep 10, 2007
When i take a picture on my camera 'FUJIFILM'
Most probably a faulty memory card. Take it out and take a test photo without it, then see if you can see the preview of what photo you took that is now stored in the built-in internal memory of your camera. If that works, then you need to replace your memory card. If even that doesn't work then your camera needs servicing.
Apr 22, 2012 | Fuji Cameras
Recently purchased Sony Cybershot DSCW180. Took 3
Yes, you need to have memory stick because camera has limited internal memory that can store few pictures only.
Put new memory card, format it through camera Menu and copy internal memory pictures to memory stick, take our memory card from camera and delete internal memory pictures either one by one or format internal memory through camera Menu.
Thanks.
Dec 02, 2009 | Sony Cybershot DSC-S950 Digital Camera
When I put the memory card in the camera it says 'cannot read' it. How do I format the card? I know it has the right 'size' memory. The memory card I am using is the same one I used a few months ago and I...
Do not use the computer to erase the card. This is the reason your camera no longer recognizes the card. Now you need to format the card in the camera to get it to work properly.
Oct 07, 2009 | Cameras
I am having trouble with computer not being able to read my memory card. Got a new memory card and I took pictures with it and they showed up on the camera put memory card in computer and said there were...
Have a look at the pins at the back of the memory card reader. You may need a torch to see to the back. My kids stuck something in my computer card slot and bent the pins so my cards would not read.
Jul 26, 2009 | Canon Digital Rebel XTi Digital Camera
Internal Memory is full??
If you dont put a memory card in your camera it is forced to record on and read from the internal memory (which is pretty small). If you do insert a memory card (is it a memory stick?) you can read the card but not the internal memory. Try it both with and without the memory stick.
Apr 29, 2009 | Cameras
Took pictures with Olympus Stylist 710, saved to a FujiFilm xD (512MB) memory card. Went to transfer pictures from memory card using Sabrent USB card reader, Mac computer did not recognize card. Now the...
It is possible that the memory card was damaged. This would be by coincidence. Just in case only the formatting is damaged you can try to format the memory card.
As far as reading the card is concerned, if the Mac has issues to read a PC format then it will not be able to read the card from your camera.
Jerry G.
Sep 28, 2008 | Olympus Cameras
Missing pictures
Hey flowernthe,
The error message “card cannot be read" means there was and error when the camera tried to access the memory card. To fix this you should make sure you are using the right kind of memory card, which for this kind of camera is a SD card, and it does not support SDHc cards. Since this camera uses SD cards I would make sure the slider on the side of the card is not set to the locked position. If this doesn't help I would make sure the memory card connecters are clean, and if they're not you can use a rubber eraser to clean them up. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 11, 2008 | Nikon Coolpix 4600 Digital Camera
Pc won't read new images off camera
Have you checked to see if you are recording to a separate file?
Mar 12, 2008 | Olympus Stylus 710 Digital Camera
Canon PowerShot A75 Digital Camera Logo
124 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
