Question about Xerox Phaser 7700 Laser Printer
Phaser 7700GX Color Printer prints wrinkled pages!
Everytime I print out something, it comes out wrinkled looking like a paper fan. Usually everything prints out ok onto the paper so the only problem I have is that it comes out wrinkled throughout the paper. Sometimes the paper tray A will jam, and I think it might be related to this or a completely different issue. Do all the print jobs come out wrinkled because the fuser was too hot? Please help! Thank you!
  • Anonymous Mar 19, 2014
    This is the second time we have had to replace the fuser in less than a year. The paper is jamming especially when duplexing. Does anyone know why the mylar is coming off? Is there something in the Konica C351 that would cause it to become loose and wrinkled?
  • Anonymous Mar 20, 2014
    I load the paper (all is smooth & no wrinkles,etc, hit print on my document page, but the paper hangs up on the right side, and says a paper jam. I have looked the printer over and over, and there is no paper jammed.
    Welcome Back:
    Visited the website for 2 consecutive days.
When this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Posted on Nov 04, 2007
How to clean phaser 7750
Included general maintenance video and how to clear smears from the paper.
Solution: Remove Print Smears / Printing Fuser Cleaning Pages
7750 Support Knowledge Base Remove Print Smears Fuser Cleaning...
With Troublshooting highlighted on the printer display perform the following steps:
  1. Press OK.
  2. Press the Down Arrow and scroll to Print Quality Problems.
  3. Press OK.
  4. Press the Down Arrow and scroll to Remove Print Smears.
  5. Press OK. The printer will print 5 cleaning pages.
Repeat this process five or six times, to remove stubborn toner buildup from the fuser.
Always make sure you are matching the type of paper loaded in the printer tray(s) to the correct Paper Type front panel setting. When you load a tray with paper, the front panel will ask you to indicate the type of paper you loaded. For correct print quality and printer operation, be sure to set this correctly.
Phaser 7750 Video Instruction Maintenance for the Printer Phaser
Apr 23, 2014 | Xerox Phaser 8550/SDP Color Laser Printer
Erratic black fusing
I'm not real sure about how the software separates the colors, but I believe there's a way to choose a color as all colors combined to make black, or simple black.
I'm not sure if I'm making any sense, but if the printer is using all the colors to layer up and make black, then it would be a pretty thick coating and that might cause it to flake off.
Oct 30, 2007 | Xerox Phaser 7700 Laser Printer
When we print something,the paper comes out and is wrinkled and has some ink on it in places where there is no print. The fuser checks out fine.
Description sounds like the fuser rollers are bad.
To check it out run a 1/2 test.
Put paper in the manual feed tray. Print something. As the paper gets 1/2 way into the printer, open the top cover,(you might have to print a few sheets to catch it just right) take out the toner and look down at the paper. If it is wrinkled, you could have a bad toner cartridge. If it looks good...get the fuser replaced.
Jun 15, 2011 | HP LaserJet P3005n Printer
Xerox phaser 7400DN jabs at fuser
The printer trays accommodate most sizes and types of paper, transparencies, or other
specialty media. Follow these guidelines when loading paper and media in the trays:
- Envelopes, labels, and glossy paper can be printed from Tray 1 (MPT) only.
- Transparencies and custom size paper can be printed from Tray 1 (MPT) and Tray 2.
- Fan paper, transparencies, and labels prior to loading them in the tray.
- Use only paper envelopes. All envelopes should be printed single-sided only. Some
wrinkling and embossing may occur when printing envelopes.
- Do not overload the paper trays.
- Adjust the paper guides to fit the paper size.
- If excessive jams occur, use paper or other media from a new package.
Mar 06, 2011 | Xerox Phaser 7400DN Laser Printer
I have a Xerox Phaser 6180MFP and when I print #10 standard envelopes and #9 renturn envelopes the envelopes come out with badly pressed wrinkles on the end of the envelope that comes out last. I have...
I am looking for a diagram on how to print envelopes with my phaser 6180 mfp - when I put the envelopes in, it keeps telling me that I need to put paper in. where can I find such diagram?
May 21, 2010 | Xerox Phaser 6180N Laser Printer
I have a customer with a Phaser 6360. The are
i think check your color space on the applications you printing from:)
Nov 24, 2009 | Xerox Phaserâ„¢ 6360/DT Printer
Phaser 7700GX getting yellow bar down the side of page on all prints
Try cleaning the Laser Unit for Yellow. Try replacing the Imaging Unit for Yellow, or simply take it out and move it to another color.... if the problem occurs on the the other color then it is definitely your Imaging Unit. One of those two is probably causing your issue.
Good Luck.
Sep 10, 2009 | Xerox Tektronix Phaser 7700GX Laser...
The Phaser 7400 starts at $2,799. see models and prices see cost per print Color: up to 36 ppm Black: up to 40 ppm First-page-out time as fast as 12 seconds 800 MHz PowerPC processor Maximum paper size: 12" x 18" All models come standard with 10/100Base-TX Ethernet connectivity Standard paper input capacity: 800 sheets Maximum paper input capacity: 3,000 sheets Finisher/stacker/stapler/hole puncher capable of handling up to 1,000 sheets Maximum duty cycle up to 150,000 pages per month What comes in the box show/hide contents Color toner cartridges (capacity: 9,000 pages each 1 ) Black toner cartridge (capacity: 15,000 pages 1 ) Imaging units (capacity: 30,000 pages per color 2 ) Waste cartridge (capacity: 30,000 pages 2 ) Fuser (capacity: 100,000 pages 2 ) Transfer unit (capacity: 100,000 pages 2 ) Finisher ships with 5,000 staples Power cord Software and documentation.
Aug 13, 2009 | Xerox Phaser 7400/N Printer
CLJ8550n poor print quality and wrinkled paper
this is usually not caused by the paper tray. this problem is usually caused by the fuser assembly. check your paper path. dead cycle the printer, shut the printer down before the paper enters the fusing area, check for wrinkles. remove all paper, print again, check the output, wrinkles, replace the fuser.
Feb 03, 2009 | HP Color LaserJet 8550n Printer
OKI C5250 Printer
My informed guess without seeing print sample is that your oki needs fuser unit replaced. Look at orange rollers should br smooth no wrinkles.
Dec 20, 2007 | OKI C5200n Laser Printer
Xerox Phaser 7700 Laser Printer Logo
660 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
