I have radio car daewoo and i need unlocking code (battery failure reason) it is two serial numbers> one above PART NO 96187482 and second 61133259. thanks in advance
DAEWOO CAR STEREO CODES. DAEWOO Car Stereo Codes. We provide car stereo audio factory original anti-theft security codes from unit serial numbers for ...
Nissan Daewoo Radio Code. You can unlock your Nissan Daewoo radio using the 17 digit DW, DS or HY serial number. You will need to find the serial number, ...
remove radio and obtain serial number from decal on the radio chassis. Email DaewooUSA with the radio number and VIN number of vehicle and they will supply code to unlock radio.
FREE and EASY methods to get your Honda radio UNLOCK CODE. (Dealerships usually charge)
Assuming you don't have the Anti-Theft Code and Serial Number that is found on the credit card sized Anti-Theft Radio Identification Card that comes with the vehicle at the time of purchase and is usually found in the glove compartment....
You have FREE options to retrieve that code by phone or on the internet BUT, the RADIO SERIAL NUMBER is REQUIRED (no matter what). (see bottom about removing ERROR E3)
***IF your Honda was made BEFORE 2001 the serial number MAY not be accessible without removing the radio from the vehicle.***
* TO GET THE SERIAL NUMBER (so that you can get the unlock code)
1. Get something to write with and on (you'll need it to write down the serial number) 2. Put the ignition key in and turn it until your able to turn your radio on (accessories position). 3. Then turn your radio OFF by it's knob/button (but leave the ignition key in place). 4. Hold down the preset buttons 1 and 6 at the same time. 5. Turn the radio on while pressing down both the 1 and 6buttons.(***IF your Honda doesn't have preset buttons on the radio then hold down the top part of the 'Seek/Skip' button AND the top part of the 'Change Disk' button instead.*** ) 6. Write down the 4 numbers you see first and then 4 more that display. These eight numbers are the SERIAL NUMBER. This is NOT your CODE. 7. Make sure your VIN (Vehicle Identification Number) is handy to get the unlock code. (can be found on your insurance card, driver's side door jam, small plate on dashboard by registration and inspection stickers, etc)
* TO GET THE UNLOCK CODE (using the radio Serial Number and VIN)
---Internet option:
1. Go to https://radio-navicode.honda.com/ (YES, it's run BY HONDA and IT'S FREE) 2. Follow on screen instructions (Serial Number and VIN required) 3. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
-OR-
---Telephone option:
1. Call American Honda Customer Relations (800) 999-1009 2. When the automated message starts 'Press 3' for 'Radio and Navigation Codes'. 3. Tell the Customer ServiceAgent you need your radio code. (They will ask for your name, your radio's serial number, VIN, etc) 4. When they give you your radio unlock code--WRITE IT DOWN and KEEP IT SAFE! 5. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
* REMOVING ERROR E3
****If you entered too many wrong codesand got an ERROR E3 message displaying you'll need to do an additional step for even the correct unlock code to work.****
Disconnect your negative battery terminal (or pull the radio fuse out if that's easier for you) for 30 seconds then reconnect it and then the radio will say "CODE" again and you can put in your correct unlock code.
*** Please click the "Was this helpful? Yes" (thumbs up)! ***
2. Put the ingnition key in and turn it until your able to turn your radio on (accessories position).
3. Then turn your radio OFF by it's knob/button (but leave the ingition key in place).
CODE.
stickers, etc)
---Internet option:
-OR-
3. Tell the Customer Service Agent you need your radio code. (They
* REMOVING ERROR E3
****If you entered too many wrong codes and got an ERROR E3 message
So what happened to begin with?
See also: http://automobiles.honda.com/information/frequently-asked-questions.aspx?Question=2
If the power from your battery to the Honda radio is interrupted the
Anti-Theft feature kicks in, the radio is rendered inoperable and the
screen reads 'CODE'. You must enter in the Anti-Theft Radio Unlock Code
(usually 5 digits) to make it operational again. You know that much by
now.
CODE.
stickers, etc)
---Internet option:
-OR-
* REMOVING ERROR E3
now.
What you have is the SERIAL NUMBER. Your almost there!!! The hard part is over! Go to the bottom below for the website option or phone number option you need to get the unlock code!!!
CODE.
stickers, etc)
---Internet option:
-OR-
* REMOVING ERROR E3
now.
1. Get something to write with and on (you'll need it to write down the serial number) 2. Put the ingnition key in and turn it until your able to turn your radio on (accessories position). 3. Then turn your radio OFF by it's knob/button (but leave the ingition key in place). 4. Hold down the preset buttons 1 and 6 at the same time. 5. Turn the radio on while pressing down both the 1 and 6 buttons.(***IF your Honda doesn't have preset buttons on the radio then hold down the top part of the 'Seek/Skip' button AND the top part of the 'Change Disk' button instead.*** ) 6. Write down the 4 numbers you see first and then 4 more that display. These eight numbers are the SERIAL NUMBER. This is NOT your CODE. 7. Make sure your VIN (Vehicle Identification Number) is handy to get the unlock code. (can be found on your insurance card, driver's side door jam, small plate on dashboard by registration and inspection stickers, etc)
---Internet option:
-OR-
1. Call American Honda Customer Relations (800) 999-1009 2. When the automated message starts 'Press 3' for 'Radio and Navigation Codes'. 3. Tell the Customer Service Agent you need your radio code. (They will ask for your name, your radio's serial number, VIN, etc) 4. When they give you your radio unlock code--WRITE IT DOWN and KEEP IT SAFE! 5. Type in the 5 digit code into your radio. This will unlock the radio and return it to a functional state.
* REMOVING ERROR E3
****If you entered too many wrong codes and got an ERROR E3 message displaying you'll need to do an additional step for even the correct unlock code to work.****
----------------------------------------------------------------------------------- So what happened to begin with? See also: http://automobiles.honda.com/information/frequently-asked-questions.aspx?Question=2
If the power from your battery to the Honda radio is interrupted the Anti-Theft feature kicks in, the radio is rendered inoperable and the screen reads 'CODE'. You must enter in the Anti-Theft Radio Unlock Code (usually 5 digits) to make it operational again. You know that much by now.
if you do not have original anti-theft radio code you will need to remove radio and retrieve s/n off of radio. once you have that you can go into nearest honda dealer and with s/n they can give you correct radio code
---Internet option:
-OR-
* REMOVING ERROR E3
