Question about Bauknecht 24 in. GSF8984 Free-standing Dishwasher
Flashing what dose f4 mean it stuck on it and reset button keeps flashing
  • sheppard3 Dec 15, 2007
    F4 is always in screen. it will work if I hold the start on, sometimes. How do I fix.
Have tried , it did not work
Posted on Aug 13, 2008
  • 44 Answers
The lights flash when the door is not shut all the way, or the sensor that detects that the door is shut is not sensing the door is shut. Try pushing in on the door while hitting the start button.
Posted on Sep 14, 2007
6ya staff
SOURCE:
How to master reset a galaxy s4 that's stuck on the carrier logo?
Turn off the phone and hold the volume up button and the home button together,then turn the phone on ( keep holding the volume up and home button ) when phone starts it will show you a secret menu, you can try rebooting it first from that menu and if it still dose not start do the same thing again but go for reset. ( this will wipe it clean,you will loose everything,so only do that as a last resort ) hope this helps
May 27, 2015 | Cell Phones
Why dose the data light keep flashing
that's normal, it means that there is data flowing. If it wasn't flashing then your router would not be working correctly.
Jun 14, 2014 | Computers & Internet
Keeps shutting of with red f4
e-mail the company or the manufactor, maybe you might be able to have a new one.
Mar 08, 2013 | Crock Pots & Slow Cookers
I have a flashing code on my kenmore electric oven, model 911.47709200. the code is F7 dc, what does it mean?
Stuck Keypad. Roper ovens with 2 Digit Displays:
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 25, 2011 | Ovens
My son has a TI-84 Plus calculator and it is completely frozen. There is a message on the screen that reads " RAM cleared". Below that message it says "Press ALPHA F1-F4 to locate shortcut menus" but it...
The calculator OS has been upgraded to the version 2.53 MP.
For this version, whenever you remove batteries (or replace them) and turn calculator ON, you are reminded to Press [ALPHA][F1-F4] to locate Shortcuts Menu.
The calculator also asks the user to press either
[1:Do NOT show Again]
[2:Continue].
Here is what these cryptic messages mean.
Certain functions implemented on the new OS are available by pressing the [ALPHA] key followed by F1, F2, F3 or F4.
Since you may forget how to get to them, the calculator gently reminds you that there are other functions accessed only by pressing the [ALPHA] key.
It also gives you the option to flash the reminder every time the calculator memory is reset (CONTINUE) or NOT to SHOW the REMINDER again.
Usually after the RAM cleared message, press [2:Continue] or any other key but [1: ] to keep being reminded how to access the new functions.
Once a key is pressed the screen is cleared and you have the solid blinking cursor.
Oct 06, 2010 | Texas Instruments TI-84 Plus Calculator
PC start directly
Explain what you mean when you say 'when i open the pc from main switch'.
Also, something you should try is updating the CMOS, or in other words flashing the BIOS firmware. Go to your motherboards manufacturers website and see if there are any BIOS updates for it.
Mar 03, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
I hope this helps you. If you require additional assistance, please let me know.
Aug 27, 2008 | Whirlpool GHW9300 Duet Washer
Bauknecht 24 in. GSF8984 Free-standing Dishwasher Logo
985 people viewed this question
Top Bauknecht Dishwashers Experts
freddyfox
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Bauknecht Dishwasher Expert? Answer questions, earn points and help others
