Question about Sony PFM-42X1 Plasma TV
42" LG plasma
Iv got coloured lines going vrtical on a third of the screen,how can i fix this?
  • ooka Sep 11, 2007
    how much is a new panel for an LG 40" plasma?Where can i get one?
    Sergeant:
  • 279 Answers
It sounds like a bad panel, which is not what you want to hear. Replacing the panel on a Plasma TV usually costs more than just replacing the TV. However a bad panel causes vertical lines exactly as you describe.
Posted on Sep 10, 2007
6ya staff
SOURCE:
How to fix blank spots on the screen that get worse when you touch the screen?
do you still have a complete picture ?,are the lines coloured,?
do the lines go from left to right or do they spread out from the blank spot in a circular direction like the suns rays?
from your description above i am sure you are describing a broken lcd screen,if i am right there is no repair feasible for this set..
Len
Aug 31, 2014 | LG 42PC3RA 42 in. HD-Ready Plasma TV
Took lg plasma tv off wall when i put it back there is a fine vertical line which changes colour
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP IN SOLVING THE PROBLEM.....
Aug 09, 2011 | LG 42PC3RA 42 in. HD-Ready Plasma TV
LG RU-42PX10C Plasma TV picture had colored lines & went black...
This will be your Y SUSTAIN board on the left hand side when you take the back off.
Plenty available on ebay, Very easy fix
Mar 05, 2010 | LG RU-42PX10 42 in. HD-Ready Plasma...
Vertical lines on screen of my 42" plasma
Capacitors on Y-Axis board beginning to fail.
Soon the bars will be permanent - get the tv fixed before they are burned into the screen.
Repair is under $200USD (mostly labor)
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 17, 2009 | LG 42PC3D 42 in. Plasma Television
Lg 42 in plasma ihave a 6 in discolored line acrossthe bottom of the screen. can it be fixed
Two causes for this failure.
1. The Y SCAN board or YSUS board failure. Your can replace the failed boards with reasonable price.
2. The PDP Panel failure. Very expensive to fix this failure.
Good Luck!
Aug 31, 2008 | LG 42PX4DR 42 in. Plasma TV
Plasma tv has no picture only sound.
IF U HAVE A INTINA U SHOULD PROBLY MOVE IT IF U DO NOT U SHOULD CALL A CABLE COMPONY ABOUT IT TRUST ME
Jan 07, 2008 | Gateway FPD2275W LCD Monitor
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG 42 PLASMA
check all inputs on tv ,also check if menu on tv is working ,make sure lines arent being produce by another source, cable box etcc..If menu and or OSD are affected .Then there is a good chance you have lightning damaged some where in signal section on tv .
Dec 03, 2007 | LG 42PX5D 42 in. Plasma HDTV
Lg 42" plasma labeled by sky
Could be a component inside is going bad which mean it'll die soon. (it just trying to tell you to save $ for a new TV) Or wire is lose somewhere. (My work pc, I touches the monitor cable and sometimes it switchs color like you described)
Aug 25, 2006 | LG MZ-42PZ14 42 in. Plasma Television
Sony PFM-42X1 Plasma TV Logo
393 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
