Question about SanDisk Sansa e200 MP3 Player
Refresh database SansaDisk e270
Refresh database in 90% and stop. al encender (turn on) mi e270 aparece la pantalla "refresh database" llegando a un 90% y se cuelga. Quisiera poder reformatear. gtpy [email protected]
  • Lahisses Apr 18, 2008
    I don't have the cd to install my sansadisk. what can i do?
Bajo fotos de mi pc y no las veo en el mps, ¿mp cambio el formato de las fotos?
Posted on Aug 07, 2009
Thanks Mixmaster - worked like a charm :)
Posted on Jan 05, 2009
Thank you it work
Posted on Jan 30, 2008
I'm running the recovery tool but that fails as well - fun
Posted on Dec 10, 2007
Tnx
Posted on Nov 10, 2007
  • 626 Answers
Sorry, no habla espanol. Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Posted on Sep 10, 2007
SOURCE:
Mi laptop cuando la enciendo no me deja entrar se va al safemode y buelbe como si la bolviera a encender
this is not a Spanish site. sorry
why post in the wrong language.?
here, i google trans late it for you;.
This PC is 16 years old and is useless.!
My guess running the first version of XP OS, (hopeless)
"My computer and I put a black screen that design safe mode mode with network safe mode with command prompt and in start windows normally and a count of 30 seconds appears ... and turns on as if it were to enter but do the same thing who can help me please ..." answer this PC is super old, buy a newer PC 2008 or newer.
your pc has zero street value, even worse dead.
spend money on newer PC.
Feb 07, 2018 | Compaq Evo N610C Notebook
Al encender la maquina aparece la leyenda de que "windows no se ha iniciado correctamente " y al seleccionar alguna opcion modo seguro , modo seguro con red , se apaga la maquina y vuelve ...
repare instalaci?n:
1. Cuando la Prensa cualquier llave inicialice del mensaje de CD es demostrado en su pantalla, aprieta una llave para comenzar su ordenador del Windows XP CD.
2. Prensa ENTRA cuando ve el mensaje Al arreglo Windows XP ahora, y entonces prensa ENTRA demostrado en el bienvenido a pantalla de Arreglo.
3. No escoja la opci?n para apretar R para utilizar la Consola de Recuperaci?n.
4. En el Windows XP que Licencia Acuerdo, prensa F8 para aceptar el acuerdo de la licencia.
5. As?gurese de que su instalaci?n actual de Windows XP es seleccionada en la caja, y entonces aprieta R para reparar Windows XP.
6. Siga las instrucciones en la pantalla para completar Arreglo.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 20, 2011 | Computers & Internet
Al encender la pc, en el monitor aparece una raya
Para aislar el problema, yo probaria el monitor con otro PC o un laptop.
Apr 17, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
Mi ricoh aficio 1013 sale error SC 552, quisiera saber a que se debe eso....!
así usted tiene un problema con la unidad de fusión, antes de llamar a un técnico que usted podría tratar de restablecer el código al entrar en el modo de servicio y restablecer el código de allí. Siga los siguientes pasos y usted podrá fácil de hacerlo:
1. pulse el botón (amarillo [C] cancelar)
2. a continuación, pulse el número en este
orden 1-0-7
3. a continuación, pulse el botón (rojo [C] parada) y por algún tiempo, hasta que en la pantalla LCD no aparece el menú de servicio.
4. cuando vas a ver el menú de servicio en la pantalla, oprima el número 1 sobre la almohadilla de número de la tecla y presione (OK) y luego con el cursor de flecha derecha al lado del botón (OK) Pulse hasta que vea en la pantalla el número [5.Mode ], cuando este está en la pantalla pulse el botón [OK] y luego otra vez con la flecha del cursor al lado de la [OK] pulse hasta que en la pantalla aparecerá el número de [810. Perdí mi código SC] cuando este aparece, pulse el número 1 en el número de teclado (confirmar que en la pantalla que está escrito el número 1 y presione juntos la tecla [OK] y la tecla para seleccionar el tipo original (esta clave se encuentraen el marco del [Aceptar]) Ahora que usted ha reinicia la máquina por la que se escuchará el sonido como empieza cuando se enciende por el tiempo que los abetos también si usted no presiona la tecla junto obtendrá un [error] en la pantalla LCD si esto suceda, inténtelo de nuevo, si después de algunos momentos de tratar de que no son capaces de reiniciar la máquina llame a un técnico.
Jan 14, 2010 | Ricoh Aficio 1013 All-In-One Laser Printer
Mi monitor se prende y luego se apaga
Mi monitor hp pavilion enciende pero luego sale monotor going to sleep y se apaga. Antes de apagarse se puede leer default en dvi cable. Que ocurre?
Mar 24, 2009 | Computers & Internet
Mi pmp carga y enciende su luz pero no quiere encender el aparato
YO TENIA UN PMP ME PASO LO MISMO. Y TEMO DECIRLES QUE MURIO, TUVE QUE CAMBIARLO, LO QUE ME DIJERON FUE QUE SE DAñO LA MEMORIA Y LA BATERIA, ASI QUE PAILA. TAL VEZ EL TUYO NO SUFRA LO MISMO
Dec 06, 2008 | iRiver PMP-140 Digital Media Player
Pantalla negra VAIO VGN-UX280P
Por lo que comentas, el problema debe haber estado en algun contacto de la pantalla que no permitia su correcto funcionamiento. El invertidor or inverter posiblemente no estaba funcionando bien. A este punto puedes si luego de cambiar los LCD el viejo volvio a funcionar es posible que el problema este alli. Puedes enviar tus LCD screen para que sean revisados y tal vez reparados para evitar un gasto mayor. Te recomiendo que sino tienes experiencia en este campo lleves tu equipo al servicio especializado.
Nov 06, 2008 | Sony VAIO VGN-UX280P Notebook
Treadmill problems.
en la pantalla no aparece la iagen y si le esta llegando el voltaje por ke no se ve??
Apr 06, 2008 | Televison & Video
SanDisk Sansa e200 MP3 Player Logo
351 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
