61" Sony Projection Television
One red, one blue and one green line going across television left to right side. Replaced STK392-010 in convergence module same problem. All fuses and resistors checked good. Any and all help would be appreciated. Rob.
  • Robert Hunt
    Robert Hunt Sep 20, 2007
    Thanks for your help.
    I had to drop this customer, the TV was sitting for over one year,now they wanted it repaired within a week.
    I would like to take my time and get the job done once and right.
    Rob.
  • wjon Apr 17, 2008
    red;blue ; and green squiggely lines all over screen; just audio works. What happened
    Genius:
  • 1,153 Answers
You replaced stk's, have you replaced return resistors in same area? And is set in Convergence Setting mode or is it has sound from picture?
Posted on Sep 10, 2007
SOURCE:
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Red,Blue,Green Image
YOu have convergence issues. Ok first question. IN your setup menu do you have the convergence option/ if you DO not then it can be a specail fusable link. fl231 if you do. next question do the picture bow in at the middle. if you do then it possibly a convergence power supply issue. next if you go into setup convergence does the crosshairs adjust up or down left to right on both blue and red. I if so then theres is a chance that it can be a convergence adjusment or a amplifer problem AS always THIS SET CAN GENERATE LEATHAL 380 VOLTS EVEN WITH SET UPLUGED SO BE CAREFULL.
Jun 20, 2008 | RCA HD52W59 HDTV Projection Television
Ok, so I Replaced stk-392-110 (2) and......
Check the resistors in the red convergence circuit right next to the Ics you will need to lift one side of the resistor out of circuit to acurately check them but usually one or two resistors will be opened when the ICs go out
May 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Kp-61v45green flickers left to right
there is a convergence board in the back of the tv that needs replaced..my tv was doing the same thing and i rto be replaced the board and it works perfect now.the part should run under 100.00 and has to be soldered in place.
Mar 03, 2008 | Sony KP-61V45 61" Rear Projection...
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Convergence Problems
GREEN-YOU HAVE TWO STK392570 CONVERGENCE ICS' GETTING READY TO FAIL.SOME FOLKS HAVE REPLACED THEM ON THEIR OWN,OR YOU CAN GET A REPAIR TECH TO DO IT FOR AROUND 300.00$.JOE TV
Oct 29, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Convergence
One of your convergence IC's has burned out and needs to be replaced. A good rule here is to go ahead and replace both STK392-110 IC's with the new improved STK392-150's. If you have never replaced convergence IC's and realigned convergence circuits, allow a qualified tech to handle it for you.
Aug 12, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Convergence
you have bad convergence ics
Apr 13, 2007 | Toshiba TP61H60 61" Rear Projection...
Televison & Video Logo
416 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
