Question about Logitech Dual Action for Pc (963292-0403:) Game Pad
Configuring gamecontroller I AM TRYING TO GET MY GAME PAD TO WORK. IT KEEPS TELLING ME TO CONFIGURE GAMEPAD. I HAVE WINDOWS XP. I HAVE BEEN IN DEVICE MANAGEMENT BUT DON'T KNOW WHAT I AM DOING.
  • pajaroloco Nov 20, 2007
    gamepadnotworquing
    President:
  • 2,961 Answers
You have to configure the buttons, go to control panel>game controllers and yours should be listed, click on it and select properties, then you follow the button set up wizard, click ok, then it's configured.
Posted on Sep 10, 2007
I need drivers for logitech chillstream gamepad,i lost mine...and i can't find them on internet...can you give me link and tell me what to do?
You don't need drivers for 7 or Vista. For windows XP go to:
http://www.logitech.com/index.cfm/441/292&hub=1&cl=us,en?osid=1
You can configure it in the control panel under game controllers.
Jan 09, 2010 | Logitech ChillStream Game Pad
USB gamepad is not detected.
Get the latest dirvers from the manufacturers website and install it on your pc.After that connect the gamepad.It should work fine.
Code 10 error is due to incomplete drivers or driver malfunction
Aug 13, 2009 | Logitech Rumblepad 2 Game Pad
LOGITECH RUMBLEPAD2 ON VISTA PC
You can start from OPTIONS in the main menu of any game and then choose CONTROLS. There if you have both the options : keyboard/gamepad, then only you can use the gamepad.
Then if you have the Gamepad option there, then select it and configure/assign the gamepad keys for your game. You can do it by going onto an option; lets say ACTION and then click the Gamepad key you want to assign. Hold down that Gamepad key and double click the mouse. There you go.Your Gamepad is up and running for your game.
Cheers.
May 04, 2009 | Logitech Rumblepad 2 Game Pad
Spiderman WoS and Incredible Hulk (2008) don't respond to gamepad
its not problem with your gamepad. Its the problem with game both games. It has a bug problem. It cant install gamepad. dont try it again & again as it may damage the game pad internal configuration. pls rate for me .
Feb 05, 2009 | Logitech (9633260403) Game Pad
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | Video Game Consoles & Games
How to use gamepads with pc games
There are two types of gamepads you can connect to your computer. One is the game port on the sound card and the other is through USB port. Either way once you plug it into your computer you need to go to control panel and configure your device. Click on Switch to Classic View first if option is avaliable. Then double click on Game Controllers. Then you have two options, if a usb device has being detected then you will be able toclick on properties and configure the device. If not, you will have to click on add and select from a list of gamepads and select the one closets to your device. Then click on properties and configure the device. Follow on screen instructions.
Now once you have done the above you will also need to configure the controller gamepad in the game itself under options and under input devices/joysticks.
Good luck! Please rate after you are completed!
Aug 14, 2008 | Computers & Internet
Emulator Project64 plays Nintendo 64 Games
sory don't have a solution i have the same prob i have a logitach wingman extreme gamepad controller and it says it is working fine but dosent work with pj64 games like perfect dark or golden eye but i can play them with my keyboard wtf ?
Feb 14, 2008 | Logitech Rumblepad 2 Game Pad
Configuration with windows xp
eash game sums offer controler suport sum dont ok one that do go in menu select losgitch gamepad should auto config it self for that game ok
Jan 23, 2008 | Logitech Dual Action for Pc (963292-0403:)...
Logitech Dual Action for Pc (963292-0403:) Game Pad Logo
174 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Alun Cox
Argospete
Argospete
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
