Question about HP Photosmart 2610 All-In-One InkJet Printer
PHOTOSMART 2610 DESCRIPTION OF PROBLEM: Power outage, all lights are blinking, on Display there are no error, it has a lot of question marks.
  • micho Mar 18, 2008
    same problem here. i leave my printer on all the time. sometimes the lights for the buttons just start blinking and have random text and ? marks on the display. usually have to cycle the power for it to work again. So far have found no solution.
  • blratATL Apr 12, 2008
    I have the same problem. We were hit by a lightning strike. I love this printer, but guess it is time to kiss it goodbye.
Have The Same Problem, Trouble Is The Cartrides Cant Come Out. There Seems to Be A Device Beneath The Cartridge The Is Raise. Cause, Probably Lightning. Suggestion New Printer
Posted on Nov 08, 2007
    President:
  • HP Master
  • 2,022 Answers
Remove the catridge and swith off and switch on. bye
Posted on Sep 24, 2007
SOURCE:
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
HP 2610 photosmart I turn it on and all of its controls blink without stopping. how can a correct this?
remove the cartridges, clean the contact points, power off & then on. either this or your cartridges are empty.
Jun 30, 2011 | HP Photosmart 2610 All-In-One InkJet...
The HP Photosmart R707 Viewfinder video light keeps blinking in red even when the Camera is switched off.
If you actually mean the power light, that is supposed to blink when you plug it in and it is charging.
If you mean the one in the viewfinder, that is an error condition, and an error message is supposed to show up in the back image display viewer.
There may not be enough battery voltage left to display, so plug it into the AC adapter to be sure.
Aug 14, 2010 | HP Photosmart R707 Digital Camera
I have an HP c7180 all in one inkjet printer and recently we had a power outage. Ever since that time the colors are all mixed up. After the power outage, I was getting this error message: ""Ink System has...
If your product is in warranty then I recommend you to contact HP support to service or replace the unit. Otherwise perform the steps given below and verify the results.
  1. Turn on the unit.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 7 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
Oct 13, 2009 | HP Photosmart C7180 All-In-One InkJet...
Photosmart 2610 with power on get Error 0x886a6916
0x error codes indicate that the product has an internal error. Try to reset the printer:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button
7. Reinsert the cartridges, and then close any open doors on the product
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
Printer keeps blinking error 0x886a6b72
HI.
have a look on here HP Photosmart 2610 All-in-One Printer
if you need the drivers they can be found on here as well
hope this helps
riz.
Dec 14, 2008 | HP Photosmart 2610 All-In-One InkJet...
Problem with HP Photosmart 2610
You need to reset the printer.. Unplug it from the power.
Then please remove the USB Cable from your PC completely.
Restart your PC without connecting USB cable back to your PC.
Now connect the USB Cable into the USB Jack from both ends and start your PC.
After doing above steps please reboot your PC finally.
And push the power button for 4 times and then power on .
Let me know the result, so I can further investigate the problem.
Oct 14, 2008 | HP Photosmart 2610 All-In-One InkJet...
Error Message Error 0x886a6b72
I contacted www.hp.com and after a while we decided it is fried.
Lightening had hit my cable box and must have got the printer too.
All it will do is flash even after trying to reset to factory settings.
Thanks for the offer
Jun 25, 2008 | HP Photosmart 2610 All-In-One InkJet...
Printer HP Photosmart 2610 all-in-one
I found this link, which i think may help you out.
http://en.allexperts.com/q/Printers-1512/error-message-HP-printer.htm
Copy&paste it in a browser!
May 30, 2008 | HP Photosmart 2610 All-In-One InkJet...
Error Message
I changed the black ink cartridge in my printer with an appropriate hp product. I am not able to insert the cartridge correctly in the system. It constantly reads, remove and receck cartridge on right. I have purchased two ink cartridges at this time. Do you think the printer is broken? Please respond.
Mar 06, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
101 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
