Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Erasing or deleting stored materials
How do I remove or delete material stored on my SanDisk 2GB Cruzer Micro USB 2.0 w/ Ready Boost -
  • 44 Answers
When you plug it in to your USB port, it should be assigned the next available drive letter that is not taken by a physical drive (your primary hard drive or another USB drive). Then you can browse the drive through Windows Explorer.
Posted on Sep 15, 2007
  • Brian Payton Sep 15, 2007
    Do you have any mapped network drives?
SOURCE:
I'm unable to find some important data stored in my Sandisk micro cruzer. I'm not sure if I accidently deleted it or if it is corrupted. Please suggest if there is a way to recover the files.
If the pen drive is working, the data is there and can be recovered. I think it could be due to virus activity. Some virus make the contents of the drive hidden, thats why user can't see the files and the space available for use is less than the capacity.
It is suggested that go to FOLDER OPTIONS - and select SHOW HIDDEN FILES. It may show the hidden files. Otherwise, you can use any data recovery program to recover the data. Please not that you should not sav/write any data to avoid overwriting the existing data.
Hope this helps!
CreativeTECH
Feb 14, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
My sandisk u3 2gb micro cruzer doenst work at school but it works at home. why?
The school computers may least require foreign devices to be introduced either that may conpromise educational materials or damage computer structures. Usually the school computr structures least require introducing resources from elsewhere to achiev experices. Enquire from the school autorities about the measn to achieving productivy with the resources already established or make mention of materials that contribute toward achieving success. An alternative arrangement is possible to make possible accessing the USB device that may contain school material like assigment made at home. The situations where devices are impeded due to compartibility may involve computer structures. For example, sundisk USB are incompartible with computers. USB disks usually have varing compartibilities also know as versitilty. The more versitle device USBs are capable of several functions. Ocne in retail enquire about the extensive feature availble prior to acquring disk media. Usualy available are data material mediums or versatile resource management disk devices. Observe the purposes of the disk media where compartibility to computer devices is one aspect. Also, the devices usefullness would include several either as educational or else type features least achievable within certain computer structures.
Feb 07, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Stick shows ready boost cache file over 1.4 MB file which will not delete as not required.
Windows Vista supports "ReadyBoost" -- namely taking some of the space on the USB memory-stick to add RAM to your computer, to make your computer perform better.
Connect the SanDisk to a Windows XP system, and you'll be able to delete that file.
Dec 03, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Hi there, I have SanDisk 16GB Cruzer Slice USB Flash Drive and every time i put it into the computer, it can't be read nor located. In the beginning i was able to use it, but after two weeks i got this...
Try reformatting it to FAT32 ... instead of MacOS Extended Journaled:
**THIS WILL DELETE ALL THE DATA ON THE DRIVE**
1. Open Finder
2. Applications 3. On the left column, you should see your thumb drive. Click on it.
4. Click on the "Erase" tab near the top
5. For "Format:" select "FAT32"
6. Click on the "Erase..." button
Nov 25, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Hey, i have a mac and i cant find the format option for my USB..
1. Open Finder
Aug 21, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do I delete previously stored data from the cruzer micro
you can right click the file then delete or re-format the whole drive
Jun 27, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
How do I erase the files from the cruzer
Connect the USB device.
Windows will assign a drive-letter, e.g., 'E:' to the drive.
Open "My Computer".
Double-click on the 'E:' drive.
Click on a file, and then press the DELETE key on your keyboard.
This will delete the file (by moving it to your 'Recycle Bin').
Or, press SHIFT-DELETE to _permanently_ delete the file.
Jan 05, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Erase Data?
If you goto My computer and click on the Appropriate Letter for your flash Drive you can then Right click on it and go to "FORMAT" and then from there click Ok or Next. This will erase all data on the flash drive. You can also physically open the drive in my computer and select everything by pressing CTRL and A at the same time and then pressing the DELETE key on your keyboard, either one works fine and will delete the data off of a flash drive. Hope my answer gets you closer to a solution. Please Help rate me if I helped you out or not I am new but a very good tech.
Aug 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do i erase pictures on my cruzer sandisk
Go to the folder where the images are stored, right click those you want to dump, then click delete.
Jul 31, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
64 people viewed this question
Top SanDisk Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
