Question about AOpen F57JS (Silver) 15 in. Flat Panel LCD Monitor
AOpen Monitor resolution set to 1024 x 768 and resolutin error continually pops up saying change resolution to 1024 x 768. HELP!!
  • 10406 Answers
SOURCE: is there a driver for an AOpen F70CS monitor that
It depends on the video-adapter inside your computer, not on the AOpen monitor.
You need a video-adapter that outputs the "native" resolution of the monitor (1280x1024@60Hz), and a device-driver that supports that resolution.
Posted on May 15, 2011
0 characters
1 Points
My computer monitor shows a message "out of range". I can't get rid of the message or show anything from my computer.
The resolution your computer is sending is greater than the maximum support resolution of your monitor that isn't working or is a resolution not supported. Connect one of the monitors that works and turn down the resolution to something small (800x600 or 1024,768) and then switch to the original monitor back, you should see a picture and can adjust the resolution to something larger that the monitor supports.
Aug 08, 2014 | Westinghouse L1928NV Monitor
Hi,i actualy bought an aoc 2243fw2k led monitor,i hav a nvidia geforce 220gt graphic card,even though i installed the latest drivers for both graphic card n the monitor,i stil cant experience high...
1920x1080 resolution is the starting point for HD video. If you have set your desktop resolution to that or anything avove then you should be running at HD resolutions. Maybe the image/video you are watching is not at a HD resolution, therefore it will appear distorted and streched (poor quality). To fully experience HD playback use video files and imaged that are at the 1920x1080 resolution and above.
Dec 16, 2011 | Computer Monitors
Resolution problem cannnot get the correct resolutin for E152FD
Hi, if your monitor is 15 inches, then you probably should set your resolution to 1024x768.
If this answer helped you, please leave a positive feedback.
Jul 18, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Resolution notice it says the best picture quality change to resalition to 1024x768 1 exit 2 disable how do i get rid of it
LCD monitors have what is called a native resolution. This is what the actual/physical display resolution is. When you try to display outside of this then you get the error. The easiest way to get rid of this is to set you video display resolution to the native monitor resolution.
If you look at the message it is saying if you hit 2 it will disable the error. To change the resolution in windows you can just right click anywhere on the desktop that is empty. This brings up the display properties. Go to the settings tab. At the lower left is a slider. Just slide it to show the desired display size in your case try the 1024x768 setting then hit apply. The screen will change and a nother window should pop up and ask if you want to keep the settings. If you take too long or say no it just resets to the prior settings. You can change it at any time.
1024x768 is a good setting it is high enough that the display is clean and sharp. And most web pages are designed around this size. Try it not only to get rid of the error but also to see what everything looks like. You can always change it back.
May 05, 2010 | Belinea 10 15 36 15" LCD Monitor
Screen says out of range
I would say that the computer is trying to use a display resolution that the monitor is incapable of displaying. You may have to lower the resolution from the PC before you get a picture. Make sure you install the correct drivers for the monitor onto the new computer and use a different monitor to adjust the display resolution to a level that the monitor is capable of displaying.
Dec 15, 2009 | AOpen F2705 17" LCD Monitor
Aopen monitor and a new Lenovo computer
resize the screen resolution to the lowest and change the monitor refresh to60 hz . then play with the refresh and then the screen resolution.
Jul 20, 2008 | Computer Monitors
AOpen Monitor
It seems a magnatic field effect plz change location or any electric equpment far away to monitor. And if this is window problem then install display driver properly.
otherwise your system in virus effect
Mar 01, 2008 | Gateway FPD2275W LCD Monitor
Screen resolution
What is your monitor manufactoring year? Because old monitor could not set up to 1024x800 pixels. Please check the refresh rate also at the monitor property tab.
Dec 10, 2007 | Gateway FPD2275W LCD Monitor
I cant get the monitors resolutin at 1440x900-60Hz and the monitor keeps going to sleep
your graphics card doesnt support the resolution that your monitors native resolution is set at.
btw, what graphics card are you using?
Nov 23, 2007 | HP Compaq WF1907 Monitor
Resolution notifier v71lcd
go into the on screen menu, select the tools menu and you can turn the resolution notifier off.
Aug 12, 2007 | NEC-Mitsubishi Nec Display Solutions...
AOpen F57JS (Silver) 15 in. Flat Panel LCD Monitor Logo
19 people viewed this question
Top AOpen Computer Monitors Experts
john h
Are you an AOpen Computer Monitor Expert? Answer questions, earn points and help others
