My 5-yr old unit keeps blowing fuses imediately after replacement. Amp is off so it is a power supply issue. Any ideas? Thank you
Chances are you have a bad bridge rectifier or diode causing the fuse to blow as transformers seldom give issues. This really isn't a hard problem to fix, there will be at least one larger capacitor fairly close to where the 2 red wires go into the PCB, that capacitor will hook to the diodes, there may be 4 separate diodes or it could be a diode bank with all 4 diodes in one enclosure, if you have a volt meter you can test and see if you get a short across the terminals, just set the dial on the meter to ohms x1 and I'm guessing you will see the meter go to 0 ohms, if you change the diode that is shorted or the bank there is a good chance it will work, your going to need some basic soldering skills though to fix it...good luck!!
Posted on Nov 15, 2017
Http://akppxo.kilof.ru/15?keyword=manual-for-boston-pv600-subwoofer-repair&charset=utf-8
download the exc file and you can fix
Posted on Nov 14, 2017
SOURCE: how do i connect my boston acoustics pv800
You need to use the LINE LEVEL connection on the pv800 (usually a rca type connector cable) and run this cable into the back of the HK 520 Subwoofer PRE-OUT connector, be sure the HK Receiver menu speaker set-up option is set to SUBWOOFER "YES"
Posted on Jun 12, 2010
Feb 20, 2017 | Boston Acoustics Audio Players & Recorders
Sep 06, 2016 | Boston Acoustics Micro90X Speaker
Oct 27, 2015 | Boston Acoustics Boston Acoustic Micro...
Apr 24, 2014 | Boston Acoustics Recepter Radio(r) HD
Jan 03, 2014 | Boston Acoustics Audio Players & Recorders
• Check that the subwoofer is connected properly, switched on and the volume turned up.
• If your subwoofer has a sleep function, make sure it is switched off.
• Make sure that the Subwoofer setting is YES or PLUS (see Speaker Setting on page xx).
• The crossover frequency may be set too low; try setting it higher to match the characteristics of your other speakers (see Speaker Setting on page xx)
• If there is very little low frequency information in the source material, change your speaker settings to Front: SMALL / Subwoofer: YES , or Front: LARGE / Subwoofer: PLUS (see Speaker Setting on page xx).
• Check that the LFE channel is not set to -80dB , or a very quiet setting (see Bass Peak Level
on page xx).
• Check the speaker level settings (see Channel Level on page xx).
Regarding the Large vs Small assignment of speakers, what they mean isn't so much the physical size but the ability to handle real bass. Large if Yes.
Jan 12, 2011 | Boston Acoustics PV600 Main / Stereo...
Nov 26, 2010 | Boston Acoustics PV1000 Subwoofer
Dec 11, 2008 | Boston Acoustics Home Audio Integrated...
Aug 28, 2008 | Boston Acoustics MicroMedia Computer...
Nov 13, 2013 | Boston Acoustics PV500 Subwoofer
777 people viewed this question
Got same problem with mine. You can do a quick check to isolate portions if you are technically inclined. Open back of unit and follow wiring from mains transformer. There should be 2x Red wires and 1x yellow wire leaving the transformer to the power pcb. They plug onto the pcb with spade connectors. Remove them and wind some insulation tape around the ends to prevent shorting. Replace the fuse and apply mains again. If the fuse still blows then it is the mains transformer. This can be purchase through any electronics supplier if shown the original.
If fues does not blow, then reconnect wires. Reapply power and check if fuse blows. If it blows this time then the pcb is suspect. You would then need to have an electronics expert look at it for you then.
