Question about Belkin F8T003 Bluetooth (F8T003V) Wireless Adapter
Belkin wireless G desktop network card
I have used this product for a long time at a pervious residence, but now have moved and am using a different modem and providor. I am with sky broadband and am using my belkin product to connect to the internet, everything says that I am connected with high connectivity but I am unable to view ANY web pages or use any internet based programs, tried to talk to sky but they wont help at all because I am using a Belkin product.. Thank you
  • Jaydeepiglet Sep 10, 2007
    Okay ive now been told, by belkin, that I need to convert my network key into a WEP network key... cos it doesn't have the right amount of digits or something. Im using a Netgear modem, so does that mean I can only talk to Netgear about this?
    See the thing is, I have no idea how to do any of that.. thanks though.
    President:
  • 2,961 Answers
What has happened is that the proxy server on your last internet connection is in need of being redetected. you will need to delete any old cookies and internet files, also check in the internet explorer tools>internet options>connection, that the the the last provider you used is trying to connect instead of sky, so either select never dial a connection or sky as your default connection. Also check that in the properties of the belkin adapter that obtain an ip address automatically is checked in the TCP/IP properties. You may also need to refresh your browser a few times before you get on the net. A good temp file and reg cleaner, is Ccleaner, it's free and available at the link below http://filehippo.com/download_ccleaner/
Posted on Sep 10, 2007
  • 2 more comments
  • andrew pester
    andrew pester Sep 10, 2007
    i didnt realise, as you didn't mention you had secured the network, as i would make sure i can connect to the net first although by default sky secures the router, but what they may mean is sky use WPA PSK encryption and your adapter may be set at WEP, therefore not allowing the correct passkey to be typed.
    If you can change tp the WPA security and also you will need to try both shared and open network to see which one is used by the router, again these options are in the belkin adapter software.
  • andrew pester
    sorry if you can change the WEP security to WPA on the adapter if you are able
  • andrew pester
    there should be a belkin icon on your desktop, open it up then look for the name of your wireless connection, sky????, then just click each tab and you will see the settings, it's very simple to do
  • andrew pester
    heres the manual its really easy to follow
    http://www.belkin.com/support/dl/F5D7050...
Acquiring network address xp
You must have at least the date right and the time otherwise you get this response. Set the time and date on your computer to solve this issue. Let me know if this works.
Dec 05, 2013 | Belkin (F5D7000) 802.11g/b Wireless...
What's N stands for in this product (Belkin F5D8053 N Wireless USB Adapter for Desktop or Notebook PC)?
Based on the 802.11n draft, N Wireless enables multiple receivers and transmitters to send and receive data using Intelligent MIMO (Multiple Input Multiple Output) spatial multiplexing techniques which greatly increases speed, coverage, and the reliability of the wireless network.
Sep 25, 2012 | Belkin F5D8053 N Wireless USB Adapter for...
Belkin wireless g dektop card part no f5d7000ak is not working in windows 7 64bit
If you are using an older Belkin Networking product, you may not have support for Windows 7 with your current software.
Software updates will be posted as they become available. Please check back if your product is not currently supported.
Some updates may still be in the process of going through Microsoft's official certification program. Although they have been thoroughly tested, they may present a warning message when the driver is being installed. These drivers will install on 32 bit operating systems but not on 64 bit systems, which is the normal and expected behavior.
Even though your product may currently not be supported under Windows 7, it may very well work on it; in the majority of cases, software and drivers for Windows Vista will work on Windows 7 without a problem.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 28, 2010 | Belkin 802.11g Wireless Desktop Network...
BELKIN WIRELESS G+ NOTEBOOK CARD
Yes and No.
It will connect to a router using B (11Mbps) or G (54Mbps) mode.
It will not connect to a router using the new N (108Mbps) mode.
The best way is to set your router to "Mixed Mode", so it adjusts to the used network cards.
Feb 13, 2009 | Belkin 802.11g Wireless Desktop Network...
Belkin Wireless G desktop card & BTHome Hub
hi..
it has been seen that due to some reason the wep key doesnot work...
u can try changing the key type to WPA instead of WEP...
go to the router page and change the security type to WPA instead of WEP..
1 more thing in vista you can use the windows utility only...how come is it possible that you are using the card utility as well..i suggest you to disable the card utility and just use the windows default utility..
vedhick.....let me know if u need steps to change the security type to WPA..
Jan 26, 2009 | Belkin 802.11g Wireless Desktop Network...
Cant find own wireless
Set the SSID on at the router side. Alternately you can enter the SSID information manually at the computer side.
Nov 23, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Wireless G Desktop Network Card
most likely at the belkin website www.belkin.com
Oct 15, 2008 | Belkin (F5D7001) 802.11g/b Wireless...
Belkin wireless router installation with a laptop that has an internal modem
Depending on the operating system that you are running, and if you have the appropriate wireless cards, you should be able to do this either with or without the modem. If you have the modem connected to one computer, and wireless cards on both computers, then your best option would be to just connect directly from one computer to the next. If you can tell me the answers to these few questions, I can help you get on the right path.
What operating system are you running? Windows XP? Vista? Macintosh?
Do both of your computers have wireless network cards? If not, then which computers have the wireless network, and which computer has the modem?
Feb 02, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
Belkin F8T003 Bluetooth (F8T003V) Wireless Adapter Logo
284 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
