Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
MAYTAG MGR6772BDW How do I program the ovens?
SOURCE: Maytag Gemini MGR6772BDW
need part 74004542
Posted on Aug 06, 2008
0 characters
1 Points
I have a Maytag Maytag MGR6772BDW. One burner fails to light
Clean out the hole that lets gas to the spark area. You can bend the ignitor probe closer or farther away so that it goes to the path of least resistance. It should lite unless the gas is not getting to the spark area.
Sep 11, 2009 | Kitchen Ranges
Maytag oven will not heat past 225 degrees.
Check to see if it is programmed for Celsius instead of Fahrenheit. eric
Jul 02, 2009 | Maytag MER5765RAW / MER5765RAQ /...
Gas oven is starting by itself
You will have to replace the ERC. Electronic relay Clock.
Feb 22, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Have Ilve oven but have misplaced the manual and we need to know the self cleaning program instructions
Here's the user manual for the Following Maytag Range Models (It covers MGR5710 • MGR5720 • MGR5729 • MGR5730 • MGR5755 • MGR5750) =>
Aug 10, 2008 | Maytag MGR5750 Gas Kitchen Range
I have a Maytag Performa free standing stove/oven. The range top works well, but the oven will not work. When you program the oven to come on, the tempeture starts at 100 then quickly goes to programmed...
I am assuming that element does not come on at all...
A good place to start is the temperature probe . If it is Reading too high, its signal the control board that it does not need to heat.
Alternately the control board may not be acting properly.
Jul 28, 2008 | Maytag Kitchen Ranges
Maytag top oven lock won't lock
Do you get any error codes? What shows on the display when you try? does it make any noises , like it is trying to lock? Is it a manual lock with a lever?
Jan 19, 2008 | Maytag MER5775Q Electric Kitchen Range
Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
Dec 28, 2007 | Maytag MER6772 Gemini Electric Kitchen...
go here:
Sep 10, 2007 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
37 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
