1998 Saturn SL Logo
hugh Posted on Apr 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need a wiring diagram
I need a wiring diagram for a 1998 Saturn SC2 so I can install an alarm system.
  • hugh Apr 12, 2009
    Don't know ... I am looking for a free wiring diagram. The initial posting was somehow messed up. Not this person's fault. I don't own a SL and don't need any information on a SL. I have another posting for a SC2. I wish there were a way for me to remove the SL from the site to avoid this confusion.
  • hugh May 29, 2009
    Solution ...
    I finally found a source for free alarm and car stereo wiring diagrams. The name of the site is the12volt.com
Ricky Gittins
Level 3:
  • Saturn Master 715 Answers
  • Posted on May 28, 2009
Ricky Gittins
Saturn Master
Level 3:
Answers
715
Questions
30
Helped
248755
Points
2077
Www.wiring-diagram.com/purchase.htm I found mine for a small price, very good diagrams.
good luck
1helpful
2001 Saturn sc2 will not drop rpms when I let go of the gas pedal.
check IAC located on throttle body
search for 2001 Saturn sc2 IAC
Wiring diagram for a 1997 saturn sc2
I use AutoZone website, they have free manuals available online. Plus at least in my area they are the most helpful.
2answers
I have a 1998 Saturn SC2 engine stutter.
Sounds to me like you need to change the transmission fluid the filter is under the air filter box and the drain plug is a 17mm on the bottom of the trans closest to the engine about mid ways between the car warm the car up good then drain the fluid beware the fluid will be hot the filter is like a oil filter it just unscrews fill with proper fluid do not over fill hope this helps you
Need wiring diagram for a 2000 saturn sc2
should be on the manifold diaghfram or you can call the saturn dealership for wiring diaghram ......
1helpful
Hi, Need help with a diagram for the starter location on a 1993 Saturn SC2 2door. I have an automatic start and car alarm system. I believe I may have a loose wire or connection, as she is acting up....
sounds as if the starter is going bad or the remote sensor is not understanding the vehicle has started but if you are trying to locate the starter simply follow the battery red or + positive cable down to the starter itself always located at the bell housing between the motor and the transmission
1helpful
2answers
1998 saturn sc2 P0303 code just came up. already
p303 is a cylinder 3 missfire I woul first check the coil and then the ingnition module, Then if this dont work you could have a bad injector. If after testing and still no fix you should check the compression in that cyl.
3helpful
Saturn SC1 SC2 1995-1999 Radio Wire/Wiring diagram
For the 1995 SC2:
http://www.modifiedlife.com/1995-saturn-sc2-car-radio-wire-diagram/
Other links on the left side of that page.
HTH.
1998 Saturn will not start after new stereo installed
it means the wiring is wrong check and look fo the ignition cable and make sur it's properly secure see the wiring is all a big maze in thesecars u have to make sure everything is wired correctly the battery wire as well
2answers
98 saturn sc2 horn keeps going off. I got a jump it started.
lock the car using the key to reset the alarm
3helpful
2answers
Belt tensioner 1998 Saturn SC2
Battery keeps going down, new battery last three months?Also screaming when started, had new belt installed and it started that.
Top Saturn Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Saturn Expert? Answer questions, earn points and help others
