Question about Mitsubishi Diamond Plus 100E Monitor
Connecting mitsubishi diamond plus 100E to macbook
ISSUE: connecting an external monitor to macbook. cust is using a dvi vga adapter. external monitor: mitsubishi diamond plus 100E (22 inch CRT) TROUBLESHOOTING/ RESOLUTION: -connected the device thru the dvi vga adapter: not working.
2 Suggested Answers
  • 463 Answers
SOURCE: mitsubishi diamond pro says "no signal"?
You have tried the monitor on more than one known good computer, yes?
I believe about 4" inside this monitor in the back the vga cable or connector connects to a board with an in-line connector. Can you see if this connector (internal to the monitor) in connected?
Good luck...
Posted on Mar 02, 2009
  • 56 Answers
SOURCE: Color temperature for the monitor
I have mine on 9300K. The whites seem whiter to me rather than the yellowy tint at lower temps.
Posted on Nov 27, 2009
0 characters
1 Points
Using with a laptop
Connection the monitor depends on the connections you have out of your Toshiba laptop.
The monitor has both VGA and DVI.
If the Toshiba has a VGA out, all you need is a VGA cable available online, computer or electronics store.
If the Toshiba has an HDMI out, you can connect it to the DVI on the monitor with an HDMI cable and an HDMI to DVI Adapter.
You can also use USB out with either a VGA converter or a DVI converter (go with DVI for the better picture). Converters can be found online at Amazon, you may also need a standard male to male DVI cable to use with the converter.
Amazon com uxcell Black Blue VGA 15 Pin Male to Male Plug Computer Monitor...
Amazon com 5m High Speed HDMI Cable Ultra HD 4k 2k HDMI Cable HDMI to HDMI...
Amazon com Rankie Gold Plated DVI to HDMI HDTV Male to Female Adapter...
Amazon com StarTech com USB to DVI External Video Card Multi Monitor...
Apr 05, 2014 | HP Pavilion F1903 19" Flat Panel LCD...
Fpd1775w monitor no signal
Are you using the VGA cord or the DVI? If using the VGA switch to DVI, maybe there is a short with the VGA plug inside the monitor. a VGA to DVI adapter on the back of pc should do the trick unless your computer has a DVI connection as well..
Jan 02, 2013 | Gateway Computer Monitors
How do i connect the lcd to my computer
The monitor appears to be DVI capable, (White connector with a grid pattern). You will need to connect the monitor to the computer using a DVI cable (White connector with grid pattern and plus sign shape on one side). If your computer is not capable of connecting to a DVI monitor check to see if the monitor has a Blue VGA (Blue Zig Zag Openings) and connect it with a VGA cable. If your monitor only has the white DVI connector and your computer only has a Blue VGA connector you will need to go to the store (Best Buy, Walmart, Etc) to buy a small adapter that will convert DVI to VGA. If you ask someone for a DVI to VGA adapter they will know what you are talking about. I hope this helps.
Mar 14, 2011 | Sceptre MNTR SCPE|LCD19' 8MS DVI...
How do I connect an Additional LG monitor to my notebook
Follow these steps :
Check whether your monitor has a DVI (digital) or VGA (analog) port, both of which are generally built in. Contact your vendor if your laptop does not have either. In this case, you can use a special adapter to connect the external monitor. These adapters are model specific and should be bought directly from the vendor.
Connect one end of the DVI or VGA cord to the DVI or VGA port of your laptop and the other end to the monitor. Your laptop should automatically identify the external monitor as a new hardware device.
Most laptops will show the desktop on both screens by default, which is known as the mirror view. You can use function keys with common combination such as Fn + F2 to toggle between the two screens. Refer to the laptop's user manual for the right key combination to toggle between the displays. Alternatively, with many laptops you can also switch to the extended desktop mode. This means your desktop screen will be stretched across both the monitors. Refer to your user manual to switch to this mode.
Oct 30, 2010 | LG Computer Monitors
How do i get my macbook pro to work with the monitor gateway VX720
You'll need a mini DVI to VGA adapter. The adapter I currently use was purchased at Best Buy for under $20. You might also try Ebay. I definitely recommend this as it is an invaluable addition to your MacBook Pro.
Mar 30, 2010 | Gateway VX 720 17" CRT Monitor
Mitsubishi diamond pro says "no signal"?
Good luck...
Mar 02, 2009 | Mitsubishi Diamond Plus 100E Monitor
Compatible with macbook?
Yes. if the macbook has DVI out. Do you have the correct adapter? DVI, you can't use the VGA adapter, you need the appel DVI out adapter.
Oct 04, 2008 | Xerox XG-91D 19" LCD Monitor
Samsung T220 monitor hook up to new macbookpro-how-pc driver only-help
I think you're using the adapter in reverse. The adapter that changes from VGA to DVI but not the other way. You should plug the adapter into the DVI out on the macbook and then plug the VGA end of the cable into the monitor. If the monitor has a DVI input then you should be using a DVI to DVI cable to hook it up.
Once you have the cable plugged in you'll need to enable dual monitors or switch to external monitor on your macbook. Don't worry about the driver's cd, they are not necessary to make the monitor work on your mac (or on a PC for that matter).
There are two great instructions on how to do this, just google for "macbook switch to external monitor"
One here.
Second one here.
Jun 04, 2008 | Samsung Computer Monitors
Mitsubishi Diamond Plus 100E Monitor Logo
Top Mitsubishi Computer Monitors Experts
Matthew Spark
Matthew Spark
Shaukat Bhutto
Level 1 Expert
Are you a Mitsubishi Computer Monitor Expert? Answer questions, earn points and help others
