Question about Kicker ZR600 Car Audio Amplifier
Red light is lit on my Kicker KX400.1
Some water fell into my Kicker KX400.1 amplifier, the green light went off and the red light came on, i opened the amp and placed it in the sun to dry out for a while but the right light is still coming on when i power it up. what is the problem and how can i rectify this problem?
  • Anonymous Mar 29, 2014
    My protection power light comes on red, did I fry my amp?
  • 752 Answers
The water shorted it out. It will need to be repaired.
Posted on Sep 15, 2007
SOURCE:
Model cx600. Why is red protection light on?
The amplifier probably was being overdriven and went into protection mode to prevent the output stage(s) from getting smoked. The amp will have to be opened up to make repairs and get it working again.
Jan 08, 2016 | Kicker Car Audio & Video
Amp flashing light red and green
Your amp went to safety mode to keep from blowing your amplifier
Sep 26, 2013 | Kicker (ZX750.1) Car Audio Amplifier
I have a kicker dx 500.1 amp and a kicker cvr12 sub. When I first hooked up worked perfect for a few minuted. Adjusted settings ont the side and it went out. Now When I power on it the protection light...
check the fuse on the power wire (+) not the ground wire .. i had a kicker 1500.1 on 2 l7 15\'s and when the bass would hit hard the fuse would vibrate and cause the amp to go into safe mode.. after re wireing the whole truck i then found out it was the 150amp fuse holder
Aug 07, 2011 | Kicker Car Audio & Video
My kicker dx 500.1 and my xpliod tens worked for all of ten seconds before the protect light went red then green keeps doing that
You are running more then 1 speaker on a 1 channel amp. You need to verify how many ohms your subs are, and what ohm you are wiring your subs to run at. Your amp is only capable of running at 2 ohms.
Here is a link to figure out how to wire them correctly.
http://www.crutchfield.com/S-FKw5viheGLo/learn/learningcenter/car/amplifiers/sub_amp_guide.html
Here is a link to your amplifiers specifications.
http://www.kicker.com/dx_amplifiers
Jun 06, 2011 | Kicker Car Audio & Video
Kicker impulse 254 amp red light on top?
1st check all of your wiring, make sure the remote wire is hooked up, check to see it the RCA's are hooked up. I know this sounds stupid, but i've done it a thousand times, check to see if you hooked up the speakers. If you checked all of those and still nothing, double check your ground. Make sure where you have it grounded, you have all the paint sanded away and its a good grounding point. The red light on the top of the amp, its not a protection light is it??
Apr 03, 2010 | Car Audio & Video
Kicker zx1000.1 the green led turns off and the red is lit
check your wiring make sure it is not grounding out check you sreaker wiring make sure they are not reversed +to- make sure it has plenty of air ti breath make sure your speakers are wired for two ohms or four it is not stable for one ohm it has a circuit protection if any one of these thins are happening it will kick the red light on and shut down.
Mar 22, 2009 | Kicker ZX10001 Car Audio Amplifier
Protection light
double check the blue stereo input wire to amp is this a new amp if not speaker channels in amp might be blown
Nov 08, 2008 | Kicker KX120.2 Car Audio Amplifier
Kicker ZR600 Car Audio Amplifier Logo
666 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Marvin
Marvin
Dalynn Turner
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
