Our Jenn-Air SVE47100 has functioned flawlessly since purchase and install in 1996. This past weekend, the oven failed to heat above 270 deg - or maybe I didn't wait long enough (45 minutes). Either way, it's no longer working as it used to. I hear a sequence of clicks when I'd expect the element to heat; 2 clicks about 1 second apart, then about a 5 second delay, followed by 2 more clicks. I'm guessing what little heating is occuring is happening between the clicks.
Electrically, the 2 breakers are ganged, and both appear to be OK - haven't checked them electrically, only visually. Broiler functions correctly, so I'm guessing I have 220V where it's supposed to be.
Can't say for sure (haven't tried in last couple of days), but I think burner/grill elements still function OK. Same for downdraft fan.
No error codes displayed, main controls all appear OK.
Any help or ideas would be appreciated.
Comment by cjk123, posted on Oct 15, 2007
I was hoping for a way to conclusively know, but I started with the element, removed it, and found it to be open-circuit when I checked it with an ohm-meter.
Thanks for the help..
2 Other Users Have The Same Problem
Comment by Guest, posted on Dec 11, 2007
I am having the same problem with my SVE47100 too. Not sure how old it is, but it's at least 3 1/2 yrs old. It's always cooked cooler than the display temp says, but it at least worked. At least it worked one day and not the next. Broiler works, but non-broiler won't get past 270 degrees now.
Comment by Guest, posted on Nov 24, 2007
I just experienced the same problem with a 3 year old unit (800). Oven won't heat over 250 degrees but everything else works fine (even the broil).
Clarification Request
by DLP1, posted on Jun 05, 2008
I have a Jenn-air double wall oven and I am having a similar problem (slow to heat), but only in one of the ovens. Is this likely the element.
Post a New problem for Jenn-Air SVE47100 Slide-In Electric
Email this problem
Can you Help with these Kitchen Ranges problems?
F1 code. Stove is beeping
Spacer for back of Range
Oven Door
I got a F2 error
starting the cleaning cycle??
