Question about Canon I990 InkJet Photo Printer
This is a Canon PIXMA MP 780!!! Waste Ink Full Problem
Waste ink full message coming on and I have to hit OK to print. I was told that this will turn to a waste ink full and my printer will stop working. I found the waste ink wells. Not much in them but I cleaned as best possible. Left side sponge had a pastic cover which I could not get back on. Need to figure out how to remove the lid on this printer so I can have better access. Biggest problem is that I do not know how to reset the timer/counter and no one wants to tell me. Shop will charge me $60 to reset and Canon sure ain't going to give it up.
  • 1 more comment
  • LifeofRiley Jan 08, 2008
    How do you get to the waste ink wells?
    I got the top lid of the MP780 off--just follow all the screws and the entire top comes off, though attached wires in the back right corner complicate setting the top to the side.
    I managed to clean the pads simply by pulling them out of their containers, but since my printer's in pieces, I'd like to do everything possible and clean the wells.
  • Anonymous Feb 11, 2008
    This is a Canon PIXMA MP 780!!! Waste Ink Full Problem problem,
  • hankonabike Dec 02, 2008
    same prob for me-cannot find it on the web. Bigger secret than how many nucularr warheads the US of A still has!!!
    And it's for an MP780. don't know how this website links this question to canon i990 printer.
    Henry
  • 30 Answers
You can try to read these articles on how to reset the waste ink full error on canon printer. http://www.fastrepairguide.com/waste-ink-full-error/how-to-repair-canon-ip1000-waste-ink-full.html http://www.fastrepairguide.com/waste-ink-full-error/canon-waste-ink-full-error.html They even provide the service tool program for reset the printer eeprom data(set as factory default).
Posted on Sep 12, 2007
How do I replace wast ink tank on canon pixma mp 780 printer
Hello! here is your solution.
1) Press the following keys in sequence: Copy-Menu-Scan-Copy-Scan.
The display will say:
SERVICE MODE
#1 SSSW
2) Press the > key (also labeled +) six times.
SERVICE MODE
#7 PRINTER
3) Press OK.
#7 PRINTER
#1 SSSW
4) Press the > key (also labeled +) four times.
#7 PRINTER
#5 INK ABS CAPA
5) Press OK.
SUCTION
XX (where XX is how full the waste ink tank is as an integer percentage)
Sep 01, 2011 | Canon Office Equipment & Supplies
Servicing the, waste ink absorber, on a Canon printer
You need to manually reset the waste tank counter.
Mar 24, 2008 | Computers & Internet
WASTE INK NEAR FULL mp 780
It means you need the ink absorbers changed, around $20.00, and a shop to reset the counters. It will stop printing when it says the absorber is full.
Nov 19, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My Canon Pixma MP 170 tells methe waste ink absorber is full...
It is a shop repair since you have to use Canon diagnostics to reset the count and clear the error. The new part is around $10.00 only.
Jul 01, 2009 | Office Equipment & Supplies
MP 450...Waste Ink Absorber Full..Does not print
1.Go to: http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
2. Menu 1, select "Multifunction"
3. Menu 2, select "Inkjet"
4. Menu 3, select "PIXMA MP450"
5. Click the "Go" button.
6. Under "Search Our KnowledgeBase", type: "Waste Ink Absorber Full"
7. Click the "Search" button
8. In the search results, select "1. ');includeTableSubmitItem(12835, 'ERROR LCD: The ink absorber is almost full. Press [OK] to continue but early replacement recommended. '); return false;" class="midredlink">ERROR LCD: The ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>"
9. In the next page, select "1. Ink absorber replacement options - MP450". A page will be displayed describing how to fix this problem.
May 16, 2009 | Canon Pixma MP450 All-In-One InkJet...
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
My canon mp 150 has a warning ink refill cartridge
After so many prints the printer gives you this warning because it is possible that the waste ink pads (that collect any spilt ink in the bottom of the printer) are full. You have two options. You can either reset the waste ink counter and the printer will run but might get some ink leakage if it has had a lot of use or replace the pad and reset the counter.
A waste ink kit for this printer is Canon part number QY5-0149-000. A quick search on the will get you the part for about £5. Too fit it you will need to take the printer apart but that is easy with a service manual from here: http://www.tradebit.com/filedetail.php/4589462-canon-pixma-mp150-printer-service-manual The manual will also tell you how to reset the waste counter.
Hope that helps.
Nov 07, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink pad full error message
plz check the website http://www.fixyourownprinter.com/forums/inkjet/50418#1
Aug 04, 2008 | Canon PIXMA MP170 All-In-One InkJet...
The waste ink disposal is almost full and it won't print
The waste ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>
WASTE INK NEAR FULL The printer has a built-in waste ink absorber to hold the ink used during print head cleaning, for example. This error message indicates that the waste ink absorber is nearly full.
Press the OK button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact a Canon1.gif service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing cannot be performed until the Waste ink tank is replaced.
this answer is directly from canon
Jan 30, 2008 | Canon Pixma iP6210D InkJet Photo Printer
Mp780 waste ink full
CANON MP 780 WASTE INK COUNTER RESET
Enter Service Mode : Menu – Scan – Copy – Scan
Select #7 PRINTER in the service mode, and
input “0” at # 5 INK ABS CAPA.
Jan 18, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon I990 InkJet Photo Printer Logo
711 people viewed this question
old marine
old marine
