Question about Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher
P button stuck
I cannot use the dishwasher because the p button is stuck and will not respond when i press it. This means that the dishwasher will not start. HELP
  • sunsetblvrd Aug 21, 2008
    The programme button seemed to be lose and wasnt doing anything so couldnt start a wash, I have un-screwed the contraol panel and its quite simple but I need to replace the plastic tray that the controls sit into if that makes sense, as the button click against plastic levers which then click the electric controls, but the plastic levers have snapped so the buttons had nothing to push against to start the controls. Can I simply replace the plastic tray that the electric control board sits in?
  • 641 Answers
The P button is a part of the control board. You should take apart the control board and see whether the P switch was just stuck and you can fix it or you should replace the unit. Good luck!
Posted on Sep 10, 2007
SOURCE:
Our machine is frozen not responding to panel buttons
You can try resetting your dishwasher.
1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
3. After that, press the Pause / Cancel / Stop button twice to clear the display.
4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
Jul 28, 2016 | Dishwashers
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
2 HOUR DELAYED KEEPS FLASHING AND NO OTHER OPTIONS WILL RESPOND
There should be a tech sheet behind the bottom plate of the dishwasher. It will tell you what the flashing light means. It is probably either the control panel or board.
You can press the hightemp & heateddry buttons multiple times to try and reset it but the tech sheet will be your best bet.
Dec 03, 2014 | Dishwashers
Kenmore Dishwasher Model 665.16719000 pushpad buttons lights flashing and won't work.
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore Dishwashers
Need manual for EX500 dishwasher
Having ploblem in starting , I press the start button but doesn't respond. I turn off the machine from the switch, then restart it and a code number comes up as PF. Don't know what that means, have no manual?
Dec 15, 2013 | Electrolux Dishwashers
Dishwasher won't start and start button doesn't light, but other buttons respond
I think you still have warranty, it sounds you have faulty control panel, even if it's new does not mean it is good.
Mar 19, 2013 | Kenmore Dishwashers
The timer doesn't respond to the buttons.
It is possible the child lock has been set. See if the button with "lock" symbol is lit up. Press the button to clear the light. Then try and press the buttons.
Jul 07, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Normal wash cycle constantly blinking no other buttons responding dishwasher wont start
one of 3 things is happening, either your "start" button is not funtioning, the door latch is not operating, so the uint doesnt recognize the door closing there fore wont operate, or the "normal" button is "stuck"( electronic switch possible shorted)
the fact that you cant get any other function out of it leads me to believe that you have a stuck button/shorted keypad. this is not available as a seperate part and requires replacing the "console with active overlay"
Mar 03, 2009 | Whirlpool GU2400XTPS Built-in Dishwasher
Smeg 24 in. DWF614SS Stainless Steel Free-standing Dishwasher Logo
601 people viewed this question
Top Smeg Dishwashers Experts
Marvin
Marvin
Norman Al-Anbar
john h
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
