Question about Maytag PAV2300 Top Load Washer
Water in my washing machine
Water drips continously into my washing machine even though I am not running the washer. It eventually fills up and I have to run the spin cycle to empty the washer. Why is it dripping when the washer is not turned on and would I need to call a washing machine repair man or plumber for this problem?
    Novelist:
    Champion:
  • 244 Answers
U will need to replace the water solenoid that is letting the water in it is a fault that does occur with all solenoids,theses are were the water pipes connect to
Posted on Sep 10, 2007
2 Suggested Answers
  • 177 Answers
SOURCE: water in my washing machine
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
Posted on May 13, 2008
MY MAYTAG FRONT LOAD AT TIME WILL FILL WHEN WASHER IS NOT ON OR WILL DRAIN AND SPIN ON IT'S OWN
It may be the water inlet valve is not shutting off the flow 100%. If water keeps trickling in, even dripping, it will eventually fill the drum. Some models have a water level sensor that will run unit thru a drain cycle to prevent an overflow situation. Try checking the unit every 6 or 8 hours to see if there is a slow build up of water accumulation. Replace inlet valve if there is.
Dec 26, 2014 | Maytag Washing Machines
Thin Twin has a slow water drip when not running
If it drips while the washer is off then you will need to replace the "water inlet valve". Here is the part you need. Here is the service manual to show you how to access the valve and replace it.
Oct 28, 2012 | Whirlpool LTE5243DQ 24" Compact Thin Twin...
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Water drip
There is a water fill valve that allows water in, mixes cold and hot water or shuts it off. Its location is where the hot and cold water hoses connect to the washer.
Get the model number off the machine and go to the web site below and you can see the valve and also the cost of the valve should you choose to fix it.
http://www.appliancepartspros.com/partsearch/
Good luck, let me know.
Regards,
Jul 31, 2009 | Washing Machines
The washer doesn't always fill up when we turn it on
Hi, Dose the water fill the first time you start it but, then will not fill in the rinse cycle? Does the water continually try to fill but never gets to the top?
I want to help.
Thanks
Vic
May 12, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Water Dripping
you need a new fill valve, even if you ulplug the washer does it still drip? If yes then you do need a new fill valve. Just turn water off at the wall so your machine don't overfill.
Oct 28, 2008 | Kenmore 24032\24036 Top Load Washer
May 13, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Maytag PAV2300 Top Load Washer Logo
135 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
