Question about RCA 32V524T TV
RCA 32V524T won't power up. Chassis # ATC010T
I've had this TV for just over a year. Went to turn it on one day and it would not power up. I here a relay clicking. i suspect the horziontal drive transistor. Does any one have a service manual or know where I can gat one?
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
I've had this TV for just over a year. Went to turn it on one day and it would not power up. I here a relay clicking. i suspect the horziontal drive transistor. Does any one have a service manual or know where I can gat one? first check power supply output if it ok than forget relay if not check power supply by dis connnecting horl. output. if it is ok check h/driver collector voltage if it is less than supply voltage than h/osc & driver ckt.is ok check h/output & its print for loose. regards thanks
Posted on Sep 11, 2007
Tv wont turn on, red flashing light
FLYBACK & HORIZONAL OUTPUT SHORTED
Apr 11, 2009 | RCA 32V524T TV
Parts for rca 32v524t / ATC010a
Hello Rick008,
Try www.electronix.com they have a wide range of parts. Just make sure to match the IHVT properly.
Thank you,
Shuttle83
Oct 04, 2008 | RCA 32V524T TV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
HELLO.! IT SOUND'S LIKE A POWER SUPPLY PROBLEM TO ME.!!! & FOR THE TIME YOU WILL PUT IN TO IT & THE MONEY .!!! YOUR BETTER OFF GETTING A NEW SET.!!!HOPE THIS HELP'S YOU.!!!"GOOD LUCK"
Jul 20, 2008 | RCA 20F511T TV
CAN IT BE FIX?
Sounds like a bad horizontal transistor and flyback transformer . Do you know how to unsolder and or solder ? If so you might have a chance . If no the avg. to get repaired is around $90.00 to $130.00 so shop around as some shops will charge more . The parts you could buy your self for around $30.00 to 40.00 . Good luck and if you think you could fix let me know and see if i can get you part numbers .
Mar 15, 2008 | RCA 32V524T TV
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Mar 14, 2008 | RCA 32V524T TV
My RCA TV
I Just started to service one of these RCA ATC-010 chassis,I found a shorted Horizontal Output transistor 2SD-3402.
This could be just a failure of the transistor itself or the transistor failed because the flyback transformer has either shorted windings or internal diodes. These parts are not expensive,I suggest replacing both at the same time to save yourself future aggravation.
Jan 28, 2008 | RCA 32V524T TV
Rca 32v524t chassis-atc010a
This sounds like something best handled by an experienced tech since the fix involves extreemly high voltages nearby,
If you have a very good knowledge of the inner workings of tv's then ask for more information.
Nov 21, 2007 | RCA TruFlat 27F520T 27" TV
replaced,off/on vol,up and down,and channel up and down.
Nov 21, 2007 | RCA 32V524T TV
RCA 32V524T- Blown fuse?
If you blew the fuse, the TV would do absolutely nothing - no lights, no sounds, nothing. It could be that the loud zapping noise you heard was the high voltage transformer arcing or shorting out. This could have caused the horizontal output transistor to short, and the set will not start as a result. You should have the set serviced by a qualified tech.
Sep 01, 2007 | RCA 32V524T TV
Television will not turn on
look on the rear of the set and find out what chassis in your set.
Aug 30, 2007 | RCA 32V550T 32" TV
RCA 32V524T TV Logo
113 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
