I am trying to install and use the Cannon DR-5010C. When I plug it into the computer it says new hardware found and downloads the drivers, the program downloads just fine but when I open CapturePerfect 3.0 or press the scann button on the machine, it tells me that no scanner is found and to check the cable. I know that the cable has to be working becasue it detected it when I plugged it into the computer. I have done this on two computers with the same result both times
Have you installed ISIS/TWAIN Drivers? If not download item 4 from this link http://software.canon-europe.com/products/0010203.asp
If you are using Vista, you must install corresponding drivers.
S. Mohan, Chennai, India
With my HP Deskjet 4100 I am able to scan thru my laptop but when I try to scan to desktop that is...
(More)
With my HP Deskjet 4100 I am able to scan thru my laptop but when I try to scan to desktop that is networked with laptop thru wired router will not let me scan. If I connect 4100 directly to desktop will let me scan. How can I get it so both computers are able to use scanner without having to disconnect and move the scanner. Both computers print fine to the 4100
I'm trying to scan a test chart into a DR-5010 scanner. It's a little wider than a regular page. I'm...
(More)
I'm trying to scan a test chart into a DR-5010 scanner. It's a little wider than a regular page. I'm using paperport 11. I changed the width and legnth using the area tab, but it still cuts off about a fourth of the chart after it scans and goes on to paperport. It shows the whole chart when I preview it, but the output isn't the same as the preview. Any suggestions?
