Question about Toshiba 50H71 50" Rear Projection Television
Toshiba Tv 50H71
I can,t turn it on and I see the red light Blinking all day.
  • chrisandmary Aug 02, 2008
    I was watching my TV and suddenly it went black...there is no picture and no sound. There is a red blinking light on the front panel. My son was playing on a Nintendo WII earlier in the day, could this have contributed to this problem. The TV is about 7yrs old.
    Genius:
  • 1,139 Answers
This is like so many sets I have seen here. This problem has to do with the shutdown circuit turning the set off to protect it. As has been said many times this is a problem with the HV section which inclused the deflection, convergence, and horizontal output. These sections can not be repaired by someone who does not have electronics experience. I would suggest that you take this telvision to a repair shop in your area.
Posted on Sep 11, 2007
6ya staff
SOURCE:
I have a toshiba - 50h71 - i get a clicking noise from the back of the tv, and the red light on the front flashes, no picture what can cause this
Toshiba Lamp 75008204 Y67
lamps-dlp.com$169.95 Toshiba Warranty 180 Days In a Toshiba Box!
You need a new lamp. simple easy fix. just cost's a bit. Thats the part number for your exact tv. You can probley find it cheaper on E BAY
Mar 11, 2010 | Televison & Video
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
Oct 11, 2008 | Toshiba TZ50V61 50" Rear Projection...
Toshiba 50H71
you need to replace both the convergence ICs they are STK392-110 you can get new replacement ICs at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 29, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50h71 red light after fixing the convergence chips
Did you check to be certain none of the resistors were burned or open that power the ICs ? This is fairly common for one or two of the convergenvce resistors to be open when the ICs go out. Also double check the iC pins to insure that none of the pins are bridged with solder. If you need more assistance please let me know.
May 19, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71 projection tv
You need to replace both of the convergence ICs they are number STK392-110 you can get new replacement ICs at the following link and they provide free instalation instructions so you can do the repair yourself which tkes about 30 minutes to do and saves you about 400 dollars. heres the link.
May 18, 2008 | Toshiba 50H71 50" Rear Projection...
Red picture toshiba model 50h71
try to turn down the screen control and see how the tv reacts.
Apr 10, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71 50 in. Rear... Problem
set most likely has bad convergence ics J.D.W.
Mar 26, 2008 | Toshiba 50H71 50" Rear Projection...
Red Blinking light
the same thing just happened to mine, i was told it might be the diplexer ??? still trying to research it though.
Mar 01, 2007 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71 50" Rear Projection Television Logo
145 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
