Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
DISHWASHER WONT FILL WITH WATER
By raynor on Sep 10, 2007
MY DISHWASHER WILL NOT FILL WITH WATER, I HAVE CHECKED FOR ANY BLOCKS AND ALL SEEMS FINE, I HAVE JUST LOOKED UNDER IT AND FOUND A SMALL LEEK IN THE WASTE PIPE JUST AS IT LEAVES THE MACHINE BUT WHEN I FILLED IT MANUALLY IN DRAINED OK COULD THIS BE MY PROBLEM. IT MAKES ALL THE CORRECT NOISES AND SEEMS TO BE ALL WORKING EXCEPT FOR THE LACK OF WATER. IS THERE ANY THING I CAN DO...
Same Problem
Dec 01, 2008
-   My machine will not fill with water. I have checked the water supply and hoses and all is OK. -   glendahaz
Nov 22, 2008
-   My dishwasher won't fill with water.-   Guest
Nov 13, 2008
-   danby ddw497w - water does not fill the diswasher. There are no leaks and the connection is done correctly-   vfiona_gy
Nov 13, 2008
-   Exactly the same problem.
To get it working for one cycle only i have to pull the machine out, turn off the water supply to it, disconnect the inlet hose, connect it again, turn on the water supply, then it works, but only for the one cycle.
To use again i have to repeat the process!!
Very frustrating considering it is not very old.-   macmandy69
Oct 31, 2008
-   same problem no water in-   sanjay695
Best Solution
posted on Sep 10, 2007
Helpful)
dovi
Rank: Guru
Rating: 88%, 2494 votes
I don't think that the problem is relates to the leaking water.
Check first the filters on the inlet water line (both sides).
Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)).
If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!
Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one.
Good luck
Was this helpful?
Yes
No
Solution #2
posted on Dec 04, 2008
Not Rated)
outlawmws
Rank: Apprentice
Rating: 0%, 0 votes
The valve has two control functions.
The basic control is does it get 120 and is the valve working, both mechanically and electrically. A resistance test will tell if the solenoid is operational. a voltage test during the fill cycle will tell whether it is getting 120.
If it is not getting 120, check the float control switch. this is a micro switch that shuts the valve off when there is enough water in the machine. It is just in front of the valve and has a "teeter toter" actuator connected to the float. On mine the metal tab on it had been bent over by a previous repair person, thus placing it in the off position. this could also be a defective micro switch of a stick float actuator that prevents the valve from coming on.
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
what brand dishwasher should i buy?
Answer
What new dishwasher do you recommend. I have a family of 7 and the dishwasher is constantly in use.
Answer
my dishwasher will not pump out the water after a wash cycle,is the pump out of action
Answer
The dishwahser sounds like it is draining and the light on the front panel is blinking.
Answer
Do you have a service manual I can download for a kenwood dishwasher KDW8ST2A? I have an error code... (More)
7 Other Users Have The Same Problem - Continued
Comment by glowilson, posted on Oct 28, 2008
my dishwasher will not release any water
Comment by mary6663, posted on Oct 06, 2008
My dishwater begins to fill with water, but won't pump it up into the wash arms. It seems it doesn't have enough pressure. Please let me know what I can look for. Thank you!
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dishwashers:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
