The same component of your phone generally handles both Bluetooth and Wifi interactions. If you've tried a factory restore and it didn't fix it, then the wifi chip in your phone has gone bad. Unfortunately it may be difficult for you to track down the part at this point, the phone has been around for a while, so there may not be much support for it. Sorry for the possible bad news. But yea, I'd suggest a factory reset (backup your data first!), and fall a repair shop of that doesn't work. This is a hardware issue.
hello d r sir,
i have problem with my sony xperia st25i that when i try to turn it on,it does not turn on and shows error.so what can i do to fix this problem?
help me please
sounds like there is a corrupt file ,, just do a factoory restore..that should solve your problems.. or you could go to the apps store and try downloading a wifi app..
Make sure your wifi switch is turned on. If that doesn't work, try taking out the battery of your laptop, waiting at least 10 seconds, and then rebooting. If THAT doesn't work, try system restore and take it back until before your wifi quit working.
Issue:
Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution:
Install the print head and ink tanks correctly iP4500 Reseat the Print Head and ink tanks iP4500
Follow these steps to reset the printer:
Turn the printer off with the Power button (if available).
Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
Unplug the printer's power cord for approximately 10
minutes, and then plug it back in. If troubleshooting a communication
issue, reconnect the data cable (not applicable to WiFi, Bluetooth or
Infrared).
Hello , I have the same problem. It just happen lately that I can't use wifi and bluetooth in my Samsung wave. I tried factory reset and still, I have still that problem.
