Question about Canon PIXMA iP4200 InkJet Photo Printer
Canon ip4200 colour magenta
The colour magenta does not print at all on my documents. it only just started to happen. all other colours print fine. i have cleaned all nozzles etc but no luck. any ideas?
  • hubba Sep 10, 2007
  • 625 Answers
The colors transfer to the printhead by gravity. the felt on the inktank must make intimate contact with the stainless steel filter in the printhead. I have a pixma ip 6000D that I had to replace the printhead inside of two years three times. the bubblejet circuitry in the printhead got burned out. New heads cost from $55 to over a hundred.
Posted on Sep 10, 2007
My MP 145 Canon cannot print red colour, but other colour are fine, what should i do? thank you
Check the Magenta cartridge, is ir empty?
Do a maintenance head cleaning (do a deep clean) - check the Magenta print head, is it still blocked.
Oct 04, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My printer is hp laserjet cp 1515n. After printing some documents it writes "printing cool down mode" and begins working very slowly. Please help me
1515n - I have the Magenta colour 'shadowing' the blue test. A mirror image of the blue text. [slightly staggered] Black is fine. Applies to all Word docs when printing in blue - can you help please?
I only use genuine cartridges.
Jules Radstock
Jul 23, 2010 | HP LaserJet CP1518 Printer
Using the IP5000 and Canon Glossy Photo Paper am
Every time I have had problem have had to replace ink.
Sep 05, 2017 | Canon PIXMA iP5000 InkJet Photo Printer
Canon IP4200 printed great photos when new. My
Although refill inks can be quite good, it is likely the cause. Several companies do make good refill inks for canon but they are specific to model lines and you have to be sure you get the right ones for photo colour.
The inks you're using are likely "universal" inkjet inks and are fine for everyday printing but are rarely ever colour corrected properly for photo.
My recomendation to all of my customers is always to keep a new cartridge handy for photos but to use the refilled ones whenever they are printing anything else as it will give you the best balance between print cost and print quality.
May 18, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Only prints in magenta
if your cartridges are new one then do this, reinstall printer driver and check in the printer driver features that you have selected print in black and colour option
Apr 02, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
No 'clay' colour. canon pixma i 4200
I'm afrade I don't know what you mean by "Clay Colour".
For a Canon, usually you have Black, Magenta, Cyan and Yellow and you MAY have Photo Magenta and Photo Cyan depending on the machine.
Print out a test page and tell me what colour is missing from that page (compair it to the one in your owners manual or the driver).
Usually a missing colour is caused by a clogged head. Use the cleaning function over and over (try at least five times). If still not working, either the head is very badly clogged, has gone bad, or the purge unit is not working. Please make sure you are using OEM ink cartridges, as I have seen refill ink cause this exact problem.'
Try soaking the bottom of the head in water overnight (not the entire head, just the bottom part). If this does not work, you will either have to replace the head or disassemble and clean the purge unit. I'd start by cleaning the purge unit since it's free. If you're not sure, call your local service provider. They can test it using a known good head but it's likely not a free service.
Dec 11, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Magenta ink colour
I had the same problem. Try cleaning the print heads. They tend to clog. Remove the cartridges, then remove the print head. Tilted slightly, it comes out easily. Run very warm to hot water over the print heads until they all run clear. Use a turkey baster to apply strong pressure to each head until it runs clear. Blow off the excess water with mouth or blow dryer. Insert into the printer and proceed to print. If that doesn't solve it, you might have a bad cartridge, but there isn't much that can go wrong with the cartridge. I have an ip4200 and an MP830. They have the same print heads and same cartridges. I have cleaned each twice and they work like new.
Sep 10, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Photo printing
if you have adobe photoshop click on image - selective colour- set the following cyan +15 magenta -5 yellow +10 black-15 this works on the pixma ip8500 so there is every chance it will work on others
Aug 18, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 misaligned colours
Make sure the guides where the copy paper is loaded, are tight against both sides of the paper.
Jun 14, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
213 people viewed this question
old marine
old marine
