Question about Umax PowerLook 2100XL Flatbed Scanner
Connecting powerlook 2100XL to computer without using SCSI interface
Please suggest me to connect Power look 2100Xl scanner to computer without SCSI card.
  • 2 more comments
  • gaianf Dec 20, 2007
    I would like to know if it is possible to use the Umax Powerlook 2100xl other than a SCSI connection.
  • Anonymous Dec 21, 2007
    We have purchased the scanner Umax power look 2100xl (p/n - 960201-11).A scsi card is with the scanner.INITIO is the make of scsi card and the numerics written on the card are pci-9100s,ao1p421,aq58g5.1 . I am facing the problem in installing the Scanner. My pc is of 64bit hardware and xp professional of 64bit is loaded on it .when I install the scsi card its not picking the driver of scsi card. Plz provide the driver of scanner and scsi card that can run on xp pro of 64bit windows.
  • vishu1 Feb 21, 2008
    please suggest me to connect Power look 2100Xl scanner to computer without SCSI card.
  • nickdclement Nov 26, 2008
    yeah, just trying to figure out what i need to hook this thing up.
PLEASE PROVIDE TOLL FREE NOS IN INDIA IN NEW DELHI
Posted on Dec 21, 2007
UMAX PowerLook 2100xl scanner termination
Only one termination should be powered in a SCSI chain. Generally, it should be the last device. It's been a long time since I've worked with SCSI, but I recall that scanners may be picky about where in a chain of multiple devices they are located; electrical noise on the SCSI data lines causes problems with the scanner electronics. I don't recall whether best results are found from locating it as the first device in line from the computer or the last device.
Aug 25, 2018 | Umax Office Equipment & Supplies
How can i run UMAX Powerlook 2100XL Scanner Driver on windows 7 professional
Many of the older model equipment are not suited for Windows 7 or to be read in 64bit using the latest computers. That is why I still keep my old computer around.
Nov 27, 2013 | Umax PowerLook 2100XL Flatbed Scanner
Scaner Umax power look 2100Xl pas di intsal kenapa tidak jalan dan scsi tidak kebaca
Windows-nya apa ? Biasanya ini terjadi karena drivernya nggak cocok sama windows. Misalnya driver installer nya hanya support sampai win vista atau XP saja, tapi di install di Windows 7 64-bit, pasti tidak akan jalan.
Semoga membantu.
Feb 04, 2011 | Umax PowerLook 2100XL Flatbed Scanner
I am running XP Pro SP3 and have installed a SCSI card and software for the scanner. When opening the utility I get error #5 cannot confirm scanner connection. Please confirm scanner's connection and SCSI...
Hello, just check you have a scsi terminator fitted to your scanner as without one you can get all sorts of bus errors. Also, keep the bus length as short as poss.
n.b. some of the later scsi devices are auto-terminating, so check the spec of your devices, and by the way,. don't plug and unplug your scsi bus whilst it is powered up as this can cause the hardware to blow (it's not like a usb plug and play bus)
Hope this helps!
nicam49
Dec 29, 2010 | Konica Minolta Dimage Scan Dual IV Film...
I have an UMAX Powerlook 2100XL. My OS is windows 7. I do not have slot for the SCSI. Is there any way to use this scanner with a USB connections
there are some Firewire to SCSI and USB to SCSI adapters that should work- check www.hamrick.com. Ed Hamrick has written Vuescan scanning software that will work with the 2100XL, windows 7 and many of these adpters
Oct 13, 2010 | Umax PowerLook 2100XL Flatbed Scanner
Can you pls. suggest which PCI Xpres card support Fi-5530C2 Scanr
Hi Karthik,
Please click on the following link for recommended SCSI cards for your Fujitsu Fi-5530C2 scanner .
http://www.fujitsu.com/global/support/computing/peripheral/scanners/scsi/
Please revert for further clarification.
Thanks & regards,
TechSatya
Jul 26, 2010 | Fujitsu Office Equipment & Supplies
I want to convert my PowerLook 2100 XL from scsi to USB. Can I?
You need to purchase a Ratoc FireWire - Ultra SCSI Converter and then a s scsi pin adaptor that will fit the Converter to the back of the scanner - and it will work on OS 10. There is also a software CD you need to install that comes with the converter. I have found I need to reinstall this Utility software every time I have shut down and restarted the system unfortunately - but it does make the scanner work - so now I just leave the CD in the computer and automatically boot it up and leave the computer and scanner on until I am finished using it for a while.
Mar 23, 2009 | Umax PowerLook 2100XL Flatbed Scanner
Trying to connect Umax PL 2100XL (SCSI) to G4 - scanner not found
I just told someone else this solution...KILL the SCSI junk...I had nothing but trouble with it with my Mac....I got a Ratoc Firewire to UltraSCSI Converter...to solve the regular SCSI to ultra SCSI problem...I also bought an adapter....It works great...no need for a SCSI card...or a driver...you just plug directly into your firewire port! If anyone can help me with my TA adapter startup problem...I'll be thrilled! Carole
Mar 23, 2009 | Umax PowerLook III Prepress Flatbed...
I need info on the make of scsi card that is bundled with scanner
It may be an old Adaptec SLIM-SCSI series. Very popular on Late 90s
1. Adaptec PCMCIA Fast SCSI Controller ( 1807600 ) - SCSI Controller ...
    "Adaptec Storage SCSI Controller Card, Storage 1807600, Adaptec PCMCIA Fast SCSI Controller."
    www.superwarehouse.com/Adaptec_PCMCIA_Fast_SCSI_Controller/1807600/p/88814
2. Adaptec SlimSCSI 1460 review - IT Reviews
    "Adaptec is the king of SCSI connectivity devices and currently offers two PC Card (PCMCIA) SCSI cards. The 1460 is the jack-of-all-trades model, ..."
    www.itreviews.co.uk/hardware/h82.htm
3. Download Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter 5.0 ...
    "Download Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter 5.0.2183.1 - Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter."
    www.soft32.com/download_171850.html
Jan 18, 2009 | Umax PowerLook 2100XL Flatbed Scanner
Umax PowerLook 2100XL Flatbed Scanner Logo
409 people viewed this question
Top Umax Office Equipment & Supplies Experts
Alun Cox
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
