Question about HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-In-One - Memory card Error
I used the Compact Flash reader on the printer to transfer some photos. Removed the card when done and now I get a "Memory Card Error" and flashing amber light. Reset power, pulled plug, rebooted computer. yelled threateningly.... nothing clears the error! Checked for bent pins on the Smart Flash socket but every thing seems fine.
  • taylordata Apr 07, 2009
    memory card error - in lcd window and flashing amber light - picked this up thru Ebay as needed a scnner pronto - scanner works ok ,dont know about the printer though as theres no cartridges ( well was only 99p ! )
    Genius:
  • 2,985 Answers
Pulling out the card without using the 'Safely remove Hardware feature' risks corrupting data on the card. Reformat the card in the camera. Also with compact flash it is a simple matter to wreck the some of the tiny pins in the card slot. Check out both these and come back
Posted on Sep 10, 2007
SOURCE:
Can I load pictures to the giinii gn 812 from iPhone
Transfer the photos from the iPhone to a computer then load the photos to the storage device of your choice and plug the storage device into the card reader of the GN 812. The GN 812 has:
  • A6 in 1 slot memory card reader and memory stick socket: SD Card, MS Card, MMC, MMC+, xD, Compact Flash (CF type 1)
  • USB Port for USB Flash Drive or cable connectivity to most cameras or PCs.
Jan 01, 2018 | Radio Communications
COMPACT FLASH ISSUES
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Aug 12, 2012 | Fuji FinePix S602 Zoom Digital Camera
I put pictures in my memory card but doesn't let me view them in my camera
You need to import the photos to your PC to view them. There are two ways to do so: connecting a camera directly to the computer via USB (Universal Serial Bus) cable and by using a flash memory reader. Using the flash memory reader is considered the fastest method to transfer images. Some of the popular types of flash memory card readers are Secure Digital (SD), Compact Flash (CF), Memory Stick (MS), Multimedia Card (MMC) and Smart Media (SM). Here is how you can use the reader to view photos from your digital camera.
Apr 12, 2012 | Vivitar ViviCam 8025 Digital Camera
I have an EOS Canon 400D digital SLR and my husband has bought me a Sony photo printer DDP-FP75 . I had wanted to be able to insert the memory card but it doesn't seem compatible. Can I print using the...
The two are not immediately compatible. The Canon EOS 400D uses a Compact Flash card. The Sony Photo Printer you have accepts SD and Memory Stick cards. Unfortunately, the CF card and SD card are very different.
The easiest solution I can think of would be for you to get an inexpensive card reader (make sure it accepts Compact Flash cards), attach it to your PC and then use it to read the CF card from your Canon EOS -- and print to your Sony printer.
I hope this helps. If it does, please rate the solution offered. My goal is always FixYa or Helpful, never TFT or IA. Regards,
Char1ieJ
Nov 24, 2008 | Canon Cameras
Internal memory??
Highly recommend that you consider using a card reader to download you pictures. You insert the camera's memory card into the reader, and then insert the reader into a USB port on your computer. The card then shows up as a hard drive so that you can simply copy/paste or drag your picture files onto your computer. Card readers are much more faster in downloading pics, do not require the use of your camera's batteries, and provide much more reliable downloading of the pictures (fewer errors). They're also VERY inexpensive these days. Here are some examples of CF card readers from Amazon:
http://www.amazon.com/s/qid=1223745821/ref=sr_st?keywords=cf+compact+flash+card+reader&rs=172282&page=1&rh=n%3A172282%2Ck%3Acf+compact+flash+card+reader&sort=price
Also, if the card has somehow become corrupted, take no more pics until you've recovered the photos. Take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
You will also need to use a card reader with this software. Finally AFTER you've recovered your photos, recommend formatting the card IN YOUR CAMERA to prevent this from happening again. Note that formatting will totally erase your card. Turn on the camera, press the menu button, select the tools menu. Go down to the selection that states your CF card's memory capacity and select it. Then follow the formatting prompts.
Oct 08, 2008 | Canon PowerShot A75 Digital Camera
Downloading embroidary designs for the Janome MC 350E
Firstly, format your compact flash card on your embroidery machine. This is presuming you have embroidery files in your jef format your machine reads on your computer. Place your compact flash in the compact flash card reader writer connected to your computer, open the compact flash card in your computer, open the file emb5. Now you can simply copy and paste a design from your computer to your flash card. It works for me. Goodluck.
Sep 20, 2008 | Janome Memory Craft 9000 Computerized...
Wat is toshiba flash card
"FLASH" generally denotes a compact storage device called
Compact Flash Card. I have an old digital camera that takes compact flash cards.
Newer Toshiba Laptops and Towers have multi card readers installed, my laptop has a SD card reader under my PCMCIA card slot. I also had a (Made for Toshiba) compact flash adapter. That device was nice because it wasn't "Card Bus" it used 8-16 bit technology making it easy to transfer data from a laptop running windows 3.1 to a laptop running Vista
Apr 13, 2008 | Computers & Internet
Sony dsc s500 and a sandisk 4gb ultra II memory card problem
There is no way to do that since the internal memory is designed to only output to cards, not the other way around. Fortunately, this should not be a problem.
In general, the best way to transfer photos to your computer is to use a card reader - it provides a standard interface that the computer will recognize, it saves wear and tear on the camera, and it saves batteries.
I use Meritline.com for things like this because they are cheap and reliable, but please don't think there aren't hundreds of other places to get one from.
To help you, here is a link to the page at Meritline that lists card readers. Note that many have free shipping:
http://meritline.com/readers.html
This is a relatively cheap one with free shipping that will handle just about any card form factor except compact flash:
http://meritline.com/all-in-one-card-reader-black-transparence.html
Good luck.
Feb 11, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
Memory card issue with Epson r300
Hi , reinstall the printer driver with sd inserted.
Jan 25, 2008 | Epson Stylus Photo R300 InkJet Printer
Compact Flash Problems
Dynamite,
have you tried to reformat the CF card?  If you deleted the image through your computer and not with the camera, the computer may have removed more than what was needed...
SteveK
Oct 27, 2007 | SanDisk ULTRA II 4GB Compact Flash Card...
HP PSC 1610 All-In-One InkJet Printer Logo
590 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
