SOURCE: USB PEN drive 2 gb not able to format
As a reference, you should be typing the following.
FORMAT X /fs:FAT32
where x is the letter of the flash drive.
SOURCE: formattin of pendrive
Your pen drive probably lost or never had a partition table. Unallocated space means the space isn't allocated to either a partition or logical drive.
Rightclick the drive in Disk Management, there should be an option to create a partition. Right after you create it. It wil ask you to format it.
Let me know whether it helped.
Please rate my solution when this was the answer to your solution.
Greetings,
DarkNeogen.
SOURCE: sandisk 2 gb pen drive not doing format insert usb
Hello friend,
You can try the following format may this can help.
Try to format the mp3 player like this method:
Go through the : Setting>Control panel>
Administrative Tools>Computer Management>Disk management>
locate you mp3 player then
Try to format fat files system.
hope this help you
Regards
uttam
SOURCE: 4 Gb pen drive can't poen
Your drive could be corrupt. The first thing I would do however is make sure you are plugging it into a good USB port. If you are using a desktop with USB ports in the front, and are plugging the drive in there, remove it and plug it in to one of the USB ports on the back of the computer. Many times the front ones will have issues with certain USB devices. If that doesn't work, you very well may have a bad usb drive. I would try it on another computer if switching the usb port doesn't help, to see if the drive is truly not working or just a driver problem on your computer.
SOURCE: My kingston 2 GB pen
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
