Question about Garmin GPSMAP 276C GPS Receiver
Downloading map to 276C
I tried to download a map from mapsource to my gps unit, but everytime it fails and give the following message: "the gps is unable to program the requested memory region. This could be due to an incompatibility between the application and the gps" after trying again, it still fails and gives this message: "The required memory for storing maps is missing from your gps. If your gps uses a programmable data card, check to make sure it is inserted properly" I'm using a blank 128Mb mapsource data card. My mapsource is version 6.13.2. Any solution is greatly appreciated. Musaraun
  • Anonymous Mar 18, 2014
    How I can read 276c memory card with out 276c gps receiver
Hi Javier, Thanks for the advice. Ur right, the data card is faulty. I had it replaced and all is well now. Thanks again.
Posted on Sep 30, 2007
I think your problem, as it was my also, is the memory card. I tried with a friend of mine's data card (memory) and is working fine, I sent my card to garming after I talk to them over the phone for an exchange. I have a 276C with 512Mb data card. I hope this help you to solve it. Javier Martinez Valencia-Venezuela
Posted on Sep 28, 2007
SOURCE:
I have mapsource loaded but while all works I cannot see any roads on the maps.Is there a special setting I have to make ?
Get your self a maual for that Garmin,,,If the answer isnt covered there,,,,,Google the same question and end up on a Garmin forum where others are talking about the same problem,,,Als see if Garmin has a toll free number for trouble shooting your unit.
Mar 11, 2011 | Garmin GPSMAP 276C GPS Receiver
I have lost my Mapsource Setup cd for my Garmin GPS
  1. Download MapSource software updater from Garmin. The version as of December 4, 2007 is 6.13.6, and the trick also works on Map Source version 6.13.5.
  2. Unpack or extract the content of MapSource_6136.exe
    downloaded using WinRAR.
  3. From the extracted files, run MAIN.msi.
  4. Then, run Setup.exe. Note: The sequence to execute Main.msi and then Setup.exe is important to avoid “Previous MapSource not found!” error.
  5. Garmin MapSource now installed.
Feb 02, 2008 | Garmin eTrex Vista GPS Receiver
Hi I have a Garmin eTrex Venture and have downloaded maps from Mapsource. When I turn on the GPS and go to the map page, no map appears on the screen.
Did you download the maps via your PC into Mapsource and then transfer them to the Venture? You have to unlock the maps on your PC with the code which is specific to your unit.
Sep 26, 2009 | Garmin eTrex Venture GPS Receiver
Need a Map Source CD for a Garmin iQ 3600 GPS
Please visit http://www.ebay.com
Search for the needed item and there you are.
rate this solution afterward.
Sep 04, 2009 | Garmin iQue 3600 GPS Receiver
Garmin zumo 550 map update problem
  1. Make a backup of your Zumo by copying all the file to your computer.
  2. Using your PC and MapSource select all the maps then send them to a SD memory card need 2Gig or bigger card.
  3. Try to rename this file to gmapprom.img and replace the same named file in your zumo. (I haven't tried this personally, so if it fails, just replace this with your backup and all will be as it was.)
  4. If this fails, you can use the SD memory card in your zumo and it will use this map instead, but it will take longer to boot your zumo.
Jan 09, 2009 | Garmin zumo 550 GPS Receiver
GPS position is offset from map location
This could be because your datum and your posistion format. Under your menu go to setup, then units and make sure you have the correct info set in there for your area. NAD27 Canada would be the one you are looking for. Give that a try and see if it works. If it is still off, consult the manuals that came with your topo and see if it says what datum it uses.
Nov 15, 2008 | Garmin 010-C0495-00 TOPO Canada - Manitoba...
Garmin streetpilot 2620 in demo mode
Do you have any unlock code for your unit? Delete this code "demo" from MapSource and put unlock code for your unit and try to download to unit a small part of maps.
Nov 12, 2008 | Garmin StreetPilot 2620 GPS Receiver
Downloading mapsets
Every time you download it wipes the entire memory card. You have to select all the maps you want stored on the card each time you add a new map. To keep from selecting all the maps everytime you want to download you can save the file in your mapsource software then just add or delete maps from your original map list.
All the mapsets that are installed in your PC should appear in the menu bar on a dropdown list. If you click on it you should see "bluechart" city navigator" etc, if you installed them correctly.
Choose one of the map sets, such as bluechart, from the dropdown list and all the maps from that set should appear on the screen.
As you select individual maps from the map set they will be loaded onto a maplist wich should appear under a tab on the left side of your computer screen.
Then go back to the menu bar and pick your next mapset, such as city navigator. A new map set will appear on the screen but the maps you selected from the previous set will still be on the map list on the left side of the screen.
I hope this helps. Please reply if you have questions about my response.
Feb 24, 2008 | Garmin GPSMAP 276C GPS Receiver
Error message on screen (read message below)
Did you tried to update your Maps? There are two maps inside your Garmin. Basemap which covers all highways and major roads and mapsource source which cover regular streets. Try reloading mapsource maps.
From the "Where to" menu select the little wrench and then select map and then select Map info. What does it say for Map Info?
If the unit is still under warranty, call Garmin and get a RMA. Return the unit to Garmin.
Dec 25, 2007 | Garmin StreetPilot C330 GPS Receiver
Map problem
There are two type of maps in the unit. There is the basemap which shows the states and major highway and roads and then there is the actual Mapsource maps which shows the streets. If you go to Mapinfo and it doesn't show anything, then Mapsource maps are missing.
With the 2610 you can use a card reader for the Compact Flash Memory card to load the maps. This is much faster since the card reader is USB 2.0 while the Garmin USB is 1.1 Under device look for the drive letter which correspond to the Campact Flash card.
Oct 15, 2007 | Garmin StreetPilot 2610 GPS Receiver
Garmin GPSMAP 276C GPS Receiver Logo
798 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
