In the UK, work on gas appliances can only be done by a Corgi Registered installer / technician. As you have a dead short, you can also call an electrician.
Nu-Flamehttps://www.nu-flame.co.uk
Home page for Nu-Flame Gas Fires UK, British Innovation, British Design and British Made including High Efficiency Gas Fires, Glass Fronted and Open Fronted ...
My thermostat used to go blank when heating. It was caused by the overheat protector inside the heater. That switch cuts the power to the heater and the thermostat. The heater could also be burned out. If it's a 24Volt system, the power supply could be bad.
I have T4 RF wireless thermostat.When you turn off heating from thermostat,for some reasons after 1 hour boiler kick on and radiator feel hot again.please give me solution.
Hi,Not nessarly shot.The stat uses low voltage from the equpitmemt also.You neea a volt meter to check.Remove stat from mounting plate.Check power at terminals RH&W or at RC&G they should read 24volt.If not check emergency switch off or fuse/breaker.
