Question about Sony DCR-DVD653E DVD Camcorder
Lens cover when i switch off the h'cam, the lens cover cannot closed.it's still open.
  • Dean Harry Feb 07, 2009
    my lens cover is stuck half way, it won't open or close. It did it a while ago but did come good but not now.
  • 752 Answers
Try giving the camera a fewsoft but forceful whacks by the lens cover area. Hard enough to possibly unjam the cover but not so hard as to cause more damage. Best to use your middle finger and tap on it like you're typing really hard. Then try to cycle it open/closed a few times. If that doesn't work it's a mechanical problem which needs to be addressed by a repair shop.
Posted on Sep 10, 2007
Dsc-P52 lens cover sticking
You need to go in and physically open the lens cover.
1. take out batteries 2. remove memory card + the small phillips screw.
3. remove the 3 remaining exterior screws. carefully with a small flat tip screwdriver pry the plastic halves slowly. eventually they will come apart. 4. at the bottom remove the small ribbon cable. 5. disconnect the mini motor wire, black and red. 6. unscrew the motor drive for the lens cover and then open the lens. 7. purchase a new lens cover motor. 8. If your screen still says turn off , then press menu and delete some files. good luck ! Work Slowly and carefully and ground your hands to a pipe somewhere before working on the unit. the static electricity could ruin the circuits !
Feb 24, 2012 | Sony Cyber-Shot DSC-P52 Digital Camera
The lens on my samsung s860 will not close (pull back)
Please disconnect the web cam from the USB port. Look for any particles on the lens cover. Insert the cam to the USB port again. This time it will close. If not, un-install and reinstall the device driver. This will definitely solve your problem.
Mar 22, 2011 | Computers & Internet
Mobile cam is problem . It shows open lens cover. I opened lens cover after that also shows like that i want clear solution for that problem.
Oct 31, 2010 | Sony Ericsson W700i Cellular Phone
My screen is blank can not see anything
do you have the lens cover open? do you get any error code or warning message? do this: make sure you have fully charged battery. close the lens cover.make sure cam is off.open lens cover by sliding it down until click is heard.if no go.close lens cover.make sure cam is off.remove the battery from cam for at least 15secs.reinsert battery.open lens cover until you hear the click.if no go try this. can you see the operational buttons and icons on the screen? if you do try to initialize the camera. touch HOME ->settings (looks like a toolbox icon) -> Main Settings (touch OK) -> [Initialize] -> [OK]. if it doesn't work service might be required.thanks :)
Mar 19, 2010 | Sony Cyber-shot DSC-T9 Digital Camera
Lens (lens cover?) only opens halfway
Hmm, this has happened to me too now. And just like the previous two posters it happened to me once before, but after switching it on and off a couple of times it corrected itself.
Now, about a month later, it has happened again. And this time it doesn't seem like it's going to open fully any more. Out of interest how long have others had their camera before this happened? How many photos had they taken?
Bobster
Jul 15, 2008 | Fuji FinePix F10 Digital Camera
"Cover Is Not Open" And The "Lens Cover" Is Open...
the lens cover switch of your camera have a poor contact that why that message is appearing...you have no choice but to disassemble the camera for repairing or cleaning that switch....i suggest you have to go the service center now and don't try open your camera if you are not a technician cause you may damage the flexwire of the lcd monitor if you not properly remove the cover...
Aug 30, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Lens Cover Closed
the switch inside that activates the camera is probably loose, or worse, broken.
Sep 09, 2006 | Sony DSC-T7 Digital Camera
Shutter problem
sand in the mechanism? Or other kind of wearout... If the lens cover does not open completely due to some mechanical problem, the camera will not work (there are switches to detect cover full open and full closed). Probably needs some repair, cleaning or replacing the cover gears
Sep 15, 2005 | Sony Cyber-Shot DSC-P52 Digital Camera
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Aug 31, 2005 | Canon PowerShot S30 Digital Camera
Sony DCR-DVD653E DVD Camcorder Logo
201 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
