Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
Failed to install
Tried to install new usb adapter to laptop to replace existing Belkin F507010 PMCIA adapter. (XP Home) Installation failed with message "There was a problem installing this hardware" "The system cannot find the file specified". After several attempts unistalled all software, drivers and oem entries. Tried to re-install origional PMCIA adapter software to revert to origional wireless card and now that fails with the same message?? So now no wirless connection at all !! Any ideas. Regards Chris Ebsworth
  • instruments Sep 14, 2007
    Thanks for the advice, Re my laptop I have given up with the usb adapter. It installed fine on my desktop so I guess it is a laptop problem.
    Having reverted to the laptop PCMCIA adapter I have tried everything I can think of and this still fails to install. The network adapter appears in device manager but the driver is not installed. I have the origional Belkin install disk which has the driver on it and I have down loadad all 3 versions from their support site but the installation still reports that there was a problem installing the device, specified file not found? Before each attempt I un-install the adapter and delete the C:\windows\inf oem.inf & oem.pif files but clearly I am missing something.
    Any ideas??
    Chris
    President:
  • 2,961 Answers
Belkin drivers are a bit of a pain, uninstall the drivers again and remove the usb adapter, and follow exactly as per instructions, normally driver first, but ignore the pop up about the driver not being a signed windows if it does, just click install anyway. toward the end of the installation you should be prompted to connect the usb adapter, the hardware should be found and then the installation should complete. If driver installed ok but the adapter cant find the the driver plug it into a different usb port and again the found hardware should pop up then install driver popup should show and you should select install automatically.
Posted on Sep 10, 2007
We've tried the belkin play wireless usb adapter in 2 laptops with xp pro and it wont connect the signals great it says the card is working properly but it just says it cant connect i've had this same...
Have you got two wireless icons down on the right by the clock. As it may be using the belkin wireless manager to control the device rather than the windows version.
Mar 11, 2011 | Belkin Play Wireless USB Adapter (F7D4101)
Belkin f5d7010
Hi there, these cards can be alittle tricky to setup sometimes. firstly are you using the drivers on the cd that came with the product, or have you downloaded new ones from belkin? The reason i ask this is because there are many differnt models of the same card and the drivers have to be a perfect match. If you are using the original drivers then i would recommend removing the card, uninstalling the drivers and rebooting. then start the installation process again and remember DO NOT insert the card before you install the drivers as this can cause installation problems also.... hope this helps..
Dec 11, 2008 | Belkin (F5D7010) 802.11a, 802.11g/b...
The Realtek EAPPkt Protocol Service failed to start
Try this..1.Try to uninstall the USB adapter and re install it again. To do this go to Add/Remove Programs under Control Panel and find the usb adapter your install in this case its Alfa Wireless USB Adapter and uninstall it and restart your computer after uninstallation. 2. Remove the USB adapter while restarting and insert it again until windows already loaded and all windows startup program have all been started.
3. System will look for the system driver of USB adapter and it will prompt you for the driver location in this window do not choose the recomended instead click browse and locate the driver cd and look for driver folder and select the applicable driver for your operating system such as WinXP if your using XP.
4. If there is no driver folder in cd, go to my computer, explore cd and run setup or install this will install the pending driver installation.
Nov 19, 2008 | Computers & Internet
Restored factory settings on pc & cant re -instal belkin adaptor
The Belkin site has very specific instructions for installing this adapter in a pc with Vista. These instructions are at: http://www.belkin.com/support/article/?lid=en&pid=F5D9050&aid=6112&scid=0
I would first unistall any Belkin Software that has already been installed, shut down the system completely and then restart. After you have fully restarted the system then follow the Belkin Site instructions EXACTLY. Any variation is apt to mean an unsuccessful install. Good Luck and have patience.
Nov 14, 2008 | Belkin 802.11g Wireless Desktop Network...
Belking Wireless G Desktop Card (F5D7000) device driver problems.
It means you downloaded a wrong driver for the device otherwise it could have installed. Check again the product and download the correct driver.
Oct 23, 2008 | Belkin (F5D7000) 802.11g/b Wireless...
Help. I have a Belkin Wireless G Router safely installed and functioning with a laptop running XP. However, I also have a Belkin Wireless G USB Network adapter that was safely running a desktop with...
is the wireless network adapter driver installed on your pc? if its properly installed you have to reconfigure the wireless network adapter to your belkin router.
wireless usb adapter should obtain the ip address from your belkin router
Apr 17, 2008 | Computers & Internet
Drivers won't install
Two possibilites here
1. the driver CD is corrupt , though belkin is a plug n play adapter, there is no need to install the cd
2. Since you getting an excalmation suggests , windows recoganises the new hardware but fails to install.
The best option is either change the manufacturer of the adapter or reinstall windows , it should fix your problem
Apr 05, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
307 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
