No scanning from Sharp ARBC260
I have a customer who has a Sharp ARBC260. They cannot scan a document everything else works fine ie. printer, fax. Can anyone help me troubleshoot this problem?
    Genius:
  • 2,985 Answers
I see this is an Office all in one. Fax works you say - sending also via the scanner? or sometihng else go into more detail of the operations of this device.
Posted on Sep 10, 2007
How do I scan document to my pc
To scan using Windows Fax and Scan
  1. Place a document on the scanner, or, if the scanner has a document feeder, place one or more pages in the feeder. ...
  2. Click the Start button , click All Programs, and then click Windows Fax and Scan.
  3. To use Scan view, at the bottom of the left pane, click Scan
More Help:
How to Scan from Printer to Computer
How to Scan Document in Windows 7
Use your computer to print scan and fax
Mar 02, 2015 | Samsung SCX 4623F - multifunction fax /...
We have a Sharp M550N copier. I know we can scan documents to email. Can we scan color documents from this machine?
It is a monochrome(black and white) copier. Generally, any monochrome machine only copies,scans, faxes, or prints in black and white only.
May 02, 2011 | Sharp AR-M550N Copier
I need help scanning a document on my hp photosmart C5200 printer/scanner. I can't find the option in menu to scan and save as document
scan by application.On your computer go to Microsoft word, go to insert then picture, from scanner or camera, choose the type of scanner you are using. Custom insert. The scanner scans your document
Sep 03, 2010 | Office Equipment & Supplies
My HP6110xi All-In-One doesn't want to scan
First, scans and copies don't really use the computer. Can you print a document from your printer. If not, then your problem is within the computer.
If it does print then....
Try using the scan feature within the HP solution center. It works on mine but the scan button on the printer does. Also some art programs have and "ACQUIRE" feature under file to scan with. (Sometimes called TWAIN.)
Hope this helps, so you can start scanning.
good luck
Feb 21, 2010 | HP OfficeJet 6110xi All-In-One Thermal...
Seems to do everything but scan to computer it will scan and print a photo but when I try to scan to computer it prompts, "place document on planten glass" well the document is on the planted glass but it...
Click Start, choose printers and faxes, choose scanners and cameras, right click WIA Canon MP970, click properties, choose events tab, choose select an event, scroll to "attach to email".
Jul 26, 2009 | Canon MP970 Photo All-In-One InkJet...
I can't use Print function for ByPass or Document Feeder?
The document feeder is used for copying and scanning ,it is a unit in a copier where you can placed your documents or originals for copying and scanning. The bypass tray is used for copying and printing, the bypass tray is used for types of paper like plain paper, acetates etc and customized papers. If you want to used the bypass tray for printing you should go to printer properties or configuration and select the tray you want to used like bypass tray .
Feb 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
When scanning document stops halfway through ADF
Have you tried lowering the resolution of the scanned document?
Nov 04, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Hi, Remote Fax Error being displayed
NOTE this option may vary to printer try USING OPTIONS TO SET CHANGES
To resolve the problem, try the steps below. After each step, try to send a fax again.
1. As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
* Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
2. Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
Note: The scanned documents will only be saved in the memory before the whole fax is sent if the Scan Before Dial option is turned on. (This is the factory default.) Up to 50 black-and-white fax pages can be stored in memory at standard resolution when there are no pending faxes in the queue.
3. Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
1. Press the Fax button, then press Options untill u see ADVANCED FAX mode.
2. Press Select.
3. Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
4. Change the setting from Yes to No using the + (right arrow) button.
5. Press Select.
Note: The Scan Before Dial option controls whether a document is scanned before a call is dialed. This parameter only applies to a mono fax that uses either 200x100 or 200x200 resolution. Higher resolution mono faxes and all color faxes are scanned after the call is dialed and the receiving machine's capabilities are known.
4. Lower the fax transmission speed 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
1. Press the Fax button, then press Options untill u see ADVANCED FAX.
2. Press Select.
3. Press Options untill u see until MAX SEND SPEED appears on the LCD display.
4. Change it to 9600 BPS using the - (left arrow) button.
5. Press Select.
5. Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
1. Press the Fax button, then press untill u see to get to ADVANCED FAX.
2. Press Select.
3. Press untill u see ERROR CORRECTION appears on the LCD display.
4. Change the setting from On to Off using the + (right arrow) button.
5. Press Select.
Nov 16, 2007 | Lexmark X4270 All-In-One InkJet Printer
114 people viewed this question
k24674
Marvin
Marvin
