Question about Mustek PL-510 Portable DVD Player
PORTABLE DVD CANNOT PLAY
THE MODEL IS MUSTEK PL510 OR AUDIOVOX D2011.I WANT TO UNLOCK THE REGIONAL CODE TO MULTI REGIONAL
    New Friend:
Wifi password hack v2.1 activation code please give me code
Posted on Nov 25, 2013
  • 3 Answers
Hi there this hack worked with my pl510......thats if you haven't already sorted it.
This Hack works on the PL510 and Pl510T
The PL510 & PL510T player is not Multiregion by default. To activate this player as Multiregion complete following instructions.
· Turn on your player.
· Close DVD disk door without a disk inserted.
· Press the following sequence of keys on your remote
control.
· Press "SET-UP".
· Press “Next” & then “Prev”.
· Again press “Next” & then “Prev”.
· Region # appears on top right hand corner of your TV
screen (1-6 being your existing region code)
· Change version (region) by pressing < button until 255
appears (correct code for Multiregion).
· Press "SET-UP" again & scroll down to exit.
· Press " SET-UP " again.
· Insert DVD disc and play.
Posted on Jan 20, 2008
  • art2105 Mar 10, 2008
    Looks like it didn't work for you try again it worked for me follow the instructions exactly.
    Art2105
    Genius:
  • 2,985 Answers
As this is a stand alone device I suspect you will not be able to do this. It has no input for revise the the firmware
Posted on Sep 10, 2007
SOURCE:
Region free code
Can you please give the make and model no. of the unit
Jun 14, 2008 | Craig 731398407019 Portable DVD Player
Audiovox portable dvd PVS6360 unlock codes
Audiovox code hack for DVD players
1. Turn the DVD player on
2. Go to the main setup page
3. In the main set up page press the numbers 9653
4. In the new menu go to region press enter
5. In region use the up and down arrow to select the region
6. Turn the DVD player off and turn it on
7. You now should have changed to the region of choice.
This hack was found on the internet. I hope this information helps you with your problem.
Dec 13, 2008 | Audiovox D1210 Portable DVD Player with...
Wrong Regional Disc.
DVDs are ecoded with region codes to indicate what area of the world they are made for. These codes may be 1,2,3, etc depending on which region they are made for.
DVD player read these codes and if the disc region code does not match the region the device is made for, the player will not play the disc.
Region 1 is for USA so most DVDp players made for use in USA require region 1 discs.
Some DVD players called multi region DVD players can be set to play different region DVDs but they are typically more expr=ensive then one region players and the code must be changed each time a different region disc is played.
Aug 27, 2008 | Audiovox D1710 Portable DVD Player with...
Unlocking region code
Hi. Same problem re TOSHIBA portable DVD player bought in the USA, model SD-P91SKN. Wonder if anyone found the solution to unlock it to multi-region? Thanks!
Jun 25, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
AudioVox D2011 LCD problem !
Aim a fan at it with it open and the cd door open for about 24 hours.
If it doesn't fix it then it will have to be replaced.
And wash your hands!
Feb 18, 2008 | Audiovox D2011 Portable DVD Player with...
AUDIOVOX D2011 - SCREEN IS BROKEN / WHERE CAN I GET IT REPAIRED?
Look on ebay, if you still see the video, then it is just the backlight that is broken. Put in your model and add the word parts to your search. Be sure to read if the parts one you are buying has a working backlight.
Oct 10, 2007 | Audiovox D2011 Portable DVD Player with...
Portable mustek dvd player
try this: power up your dvd without a disc. using your remote keypad input 9735. a secret menu should apprear. select your region code or choose 0 which will allow all discs to play. this will work with the mp70c but not with all mustek models. other solutions are available with an exhaustive google search
Feb 11, 2007 | Mustek MP70C Portable DVD Player
PL607 Not Operating
Do not buy any portable appliance with Mustek brand. After-sales support is very poor. The only solution for this troubled unit is through it in your trash can.
Feb 15, 2007 | Mustek PL-607 Portable DVD Player with...
Mustek PL-510 Portable DVD Player Logo
454 people viewed this question
Top Mustek Televison & Video Experts
pracash
Level 1 Expert
Nidhish Ganga
Nidhish Ganga
Are you a Mustek Televison and Video Expert? Answer questions, earn points and help others
