Question about Lexmark T642 Laser Printer
Printing from Server applications
I have a Lexmark T642 printer. This printer is connected to a user's PC via a USB cable. I pull the printer into the server using the run cmd to get the properties and to install printer. When I first get the printer to install on hte server I can print from the application that runs on the server. About an hour after I install the printer onto the server it quits printing from the application on the server.
That is what I ended up doing after I made the post. For the users not by this printer I can set their defaults to their own local printer.
Thank you
Posted on Oct 18, 2007
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Lexmark Master
  • 1,362 Answers
Is this printer set up as the default?
Try
file
Print
right click on the printer
go to properties
set as default
Can i connect usb port to printer port for network printing
No. The USB port on your cable modem is intended to be used only for connecting a pc to the network. Sorry for the bad news.
For network printing you can use a dedicated print server like Edimax ps-1206u, a great device that make even old printers to get on the network via USB and Ethernet ports it haves
Aug 07, 2011 | Linksys CM100 Cable Modem
My Printer Lexmark X4580 will not scan. I get the following message-Cannot retrieve Application List. Printing and copying works fine.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If your printer is connected via the USB cable, disconnect your printer from your computer. Reboot your computer. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to scan again.
If that doesn't help, try to reinstall the printer software on your computer. This will help repair any corrupted files necessary for scanning or printing.
Jun 27, 2011 | Lexmark X4580 InkJet Printer
I am running this Lexmark 6150 printer connected to the computer via usb cable. I have a wireless laptop, how can I print on the Lexmark 6150 from the laptop the laptop is connected to the same modem...
You can enable printer sharing on the computer where the printer is connected, then share the printer so it can be accessed by others on the network. The steps vary depending on which version of Windows the computer is running, so use the help screen. The steps will be listed for you to follow.
On your wireless computer, add the Lexmark printer as a network printer. You will probably need to install the printer drivers, so have the CD handy or download them from Lexmark's website.
Make sure both computers are members of the same workgroup, or the wireless computer won't be able to find the printer on your network. Also, the computer the Lexmark printer is connected to must be on and running for printing over the network.
An easier way to share your printer is by using a USB print server. One example is here. The server connects to your printer by the USB cable, and by an Ethernet cable to one of the wired ports on your router. Then any computer on the network can use the printer at any time.
Jan 09, 2011 | Lexmark X6150 All-In-One InkJet Printer
Lexmark X4550 not printing in Vista can't enable bi-directional
"Bi Directional Printing" is a statement of Parallel Port printing. Are you connected from your PC to the Printer via the parallel port?\
Did you disconnect the USB cable form the PC and then delete the current driver prior to installing the Win 7 driver?
Nov 18, 2009 | Lexmark X4550 Multifunction Wireless Color...
Lexmark T642 - print is very light
take the cartridges out and clean the spot they go into then clean them off also
Jan 19, 2009 | Lexmark T642 Laser Printer
ERROR 1208 LEXMARK 4270 LOST MY MAN. WHAT DOES THIS MEAN. WILL NOT PRINT HELP!!!!!!
Important News Attention Windows Vista Users: Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct Vista driver for your model.
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
Dec 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
Cannot connect my printer to my computer
This came right off of the lexmart site
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Nov 16, 2008 | Lexmark X3470 All-In-One InkJet Printer
Lexmark 1290 on Vista Printing Blank Pages
Fond this on the Lexmark Website. Hope it helps.
· 1) Disconnect your USB cable from your printer.
· 2) Uninstall all Lexmark printer drivers on your PC.
· 3) Download the correct Vista driver for your model.
· 4) While leaving the USB unconnected, Install the driver on your PC.
Oct 31, 2008 | Lexmark X1290 All-In-One InkJet Printer
Lexmark T642 Slow Slow Printing
I've had this problem with the Lexmarks's T640 printers connected via USB to Mac OS 10.5.5 machines.
Problem: The Mac OS' default resolution of 1200 DPI for this printer causes the printer to have to rasterize the print job again AFTER it arrives at the printer. The printer does a painfully slow job of this.
Solution: Change the default resolution of your print jobs to "600dpi".
Instructions:
1.)Call up the printer settings menu by starting a print job and clicking the up-arrow next to "Printer" box.
2.)Click on the drop-down list with the name of your application and choose "Printer Features".
Change your resolution to "600dpi". Oddly, I find that "1200dpi Image Quality" is almost as fast.
3.)It might be a good idea to "Save as" this new configuration in the "Presets" menu at the top of your list.
You should notice a tenfold increase in the time it takes the printer to actually produce print jobs now.
Additionally, in the "Color Matching" settings (you can get there by changing from the "Printer Features" settings), be sure that you are using "ColorSync" so your printer isn't having to do any additional processing in that area.
Apr 10, 2008 | Lexmark T642 Laser Printer
Problem printing to wireless print server
I have a lexmark z715 printer that won't work my pc is a emachine windows xp please contact me at noahmackey@bellsouth.net
Jan 15, 2008 | IBM Lexmark Z715 InkJet Printer
Lexmark T642 Laser Printer Logo
75 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
