Question about Hitachi 43FDX15B 43" Rear Projection Television
Alignment breakdown.....? I was recently given a 43" Hitachi, because the owner has had enough of the same problem. The colors are all misaligned, making it look like you have three images, each of a different color. The owner had it repaired about 6 years ago, but the problem has returned. He vaguely remembers the part costing about $120.00 and taking less than 10 minutes to replace. Any idea what it may have been, and could I replace it myself? THANKS!! Swa
  • jhood01 Dec 06, 2007
    The problem I am having is that green color is almost non-exixtant, as well as being out of line with the others. There is a slight green ghost at all times. I have cleaned the lenses and mirror. Also I loosened the adjusting wingnuts and tried to align and focus all 3 lenses. The red and blue look great, better than new. The only way to stop the green ghosts is to completely block the green lense. Any suggestions would be greatly appreciated. you can reach me at jhood01@yahoo.com
The most likely cause for this is a problem with the convergence circuit. This consist mainly of 2 ICs and a set of resistors. It does take some skils with soldering and electronics to replace the ICs and resistors. The 'convergence kit' is available from some web based electronic stores which includes 2 ICs - STK392-150 and a set of resistors. The authorized Hitachi supplier is Tritronics, but may be available at your local electronics supply stores. Hope this helps. clickace
Posted on Sep 11, 2007
Red color is out of alignment
The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have shadows colors pictures or 3D pictures look like.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must require chaging to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 20, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Convergance issue
No colors alignment to any colors R,G,B.The tv convergence board are dead.The 2 STK convergence ICS and some or all it resistors must be to replaced to solved convergence problems.The shop will cost U $300-350 for parts and labors.
Jul 06, 2010 | Hitachi 43GX01B 43" Rear Projection...
Hitachi 43fwx20b magic focus the 3 colors are not adjust.
First have the convergence IC's replaced these are the two large black IC's mounted on an metal heat sink.
Oct 24, 2009 | Hitachi 43FWX20B 43" Rear Projection...
I think its called a convergance problem. or maybe color alignmen
Hitachi convergence amps - It sounds like you are pretty proficient in repair - here is the potential fix and parts needed for the repair - Hitachi uses Convergence Amplifiers
http://www.hometheatershack.com/forums/service-support/5600-crt-based-rptv-convergence-repairs-post43743.html#post43743
Dec 19, 2008 | Hitachi 43FDX20B 43" Rear Projection...
HITACHI ultrascan hd tv....
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 24, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi ultrascan hd 42 in
The problem you are facing is a common problem in all rear projection TVs. It's called convergence. If you go into your menu there is an adjustment for it. if it doesn't move back into alignment then you have a more serious problem in the convergence circuit which will require replacement of components.
C-Dog
Feb 05, 2008 | Hitachi 43GX01B 43" Rear Projection...
Hitachi 53UWX10B Projection TV - Color Separation
Common problem on all rear projection TV's...............
Somewhat difficult,requires chassis pull and solder in new parts.
Part # stk392-110 subs to upgrade stk394-160E part # CZ 01341
Dec 12, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Problem in Hitachi 43" tv
Common failure called convergence mis-alignment.Needs
convergence IC's replaced by skilled technician.Good set
to keep going a few more years.............T.
Please rate this solution...................
Nov 15, 2007 | Hitachi 43FDX01B TV
Hitachi help
you require an alignment,you must enter the service mode to adjust and save the settings.
Jan 09, 2007 | Hitachi 43F300 43" Rear Projection...
Hitachi 43FDX15B 43" Rear Projection Television Logo
73 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
