Question about Radio Communications
GE 3-5814a cb
The unit has no transmit or receive audio, what could be the problem..
    Problem Solver:
  • 19 Answers
Sounds like a voltage regulator to me. the speaker would not have anything to do with the transmit, the receive yes but, with no transmit or receive try the voltage regulator number on it will be ta7217 it will have roughly 10 legs on it and it will be attached to a heat sink or the chassis of the radio. also you might look at where the antenna wire connector screws on to the radio, on the inside of the radio on the back of the connector there should be a wire coming from the back of the plug and connecting to the circuit board , it could have came loose. Good luck.
Posted on Sep 11, 2007
  • 123 Answers
Check if the battery level is correct, agree with the checking the speaker. does appear any tx icon on the display when you press the ptt key?
  • 3 Answers
First of all i would check the speaker, can you get feedback or even a 2Kilohertz tone? Is there any popping or cracking coming from the speaker?
No audio transmit or recive
check your final for voltage, work your way from IC 1 on up then check audio transistor . Work your way through the transmit section then the receive section . Check your volume control ,make sure its working alright Just have patience and it might jump right out at you.
Dec 15, 2015 | Cobra 25 WX-NW-ST 40-Channels Base CB...
Problem no squelch noise or speaker like its muted, but can hear weather ok shows receiving and ant ok
Since the radio cannot transmit on Weather bands, there is no need for the radio to detect if it is transmitting when receiving weather.
In CB mode (on CB channels) the radio will mute when transmitting. So... a guess is that it is muting, or transmitting all the time in CB mode. Check for a mic problem by removing the Mic from the radio ... if it receives CB with no mic connected, then there is an issue with the mic. Otherwise, unless the unit is in PA mode (public address mode) it is likely something internal and beyond the scope of this service.
Sep 08, 2015 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
Galaxy melaka ssb receives but wont transmit whats the fix
look for other fingers that have been in the radio. then back track from there. It could be a switching diode thats burnt.
Jan 27, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
How to wire a HG M73 mike to a galaxy DX 959
Stock
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Cobra
Stock
1- Audio
2- Transmit
3- N/C
4- Shield
5- Receive
Dec 04, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
On a cobra mike what color wires are transmit,receive, auto ,common
Hi, my name is John. Welcome to FixYa. # 1 is the shield, # 2 is audio- white, #3 is the transmit- red, #4 is the receive- black. Good luck and thanks for choosing FixYa...John
Nov 02, 2010 | Cobra 29 LTD CB Radio
Receivers complain about squeeling noise from my midland 1001z when I transmit. Is this an RF Gain setting problem?
I had the same (squealing) problem on transmit with the Midland 1001Z when I used it indoors as a base unit. The problem was my power supply: it broke into oscillation when drawing more than 150 mA at 13.8V. The 1001Z draws about 150 mA on Receive, and much more (but only about 900 mA) on Transmit. If using the 1001Z as a base unit, I suggest you power it with a fully-charged car battery indoors, or test your power supply to check if it can't supply the required 1 Amp, approx., on Transmit. It's a GREAT radio, just give it a good power supply. My power supply was defective out of the box, but now I have a good one and get great reports on signal strength and audio quality. Remarkable, for the low price and 3 year warranty. Good luck!
--Sky Junkie / Tucson, AZ / USA
Sep 27, 2009 | Midland 1001Z 40-Channels Base CB Radio
Cb problem have a cobra 19dx iv with a 2ft magnet mount cobra antenna swr is good, receive is good, but muffled output
Hi and welcome to FixYa,
Which output is muffled, transmit (modulation audio) or receive audio?
If you are referring to the receive audio, initially, have you tried an external speaker? If it works good, then it would be an internal speaker problem; if not then others to check would be:
  • IC1 - KIA7217AP audio IC;
  • CM 10 & 15 - audio output capacitors 470uF / 16V.
if it were transmit / modulation audio, try replacing the mic.
Please postback updates.
Good luck and thank you for asking FixYa.
Aug 01, 2009 | Cobra Radio Communications
Correct wiring for a ASTATIC TEARDROP MIKE to a RANGER RCI 2950DX
here is the info you asked for the following is the correct wiring.
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Turner 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Black
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Turner 6-Wire MIC. Wiring
1. Ground Shield & Red
2. Audio White
3. Transmit Blue
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 6-Wire MIC. Wiring
1. Ground Shield & Blue
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Mar 11, 2009 | Connex 3300 240-Channels Base CB Radio
Diesel #8-32 echo power mics
cobra 4 pin is pin1= shield, pin2= mic audio (usually the shield is wrapped around the mic audio wire).pin 3= transmit or push to talk usually red or white whichever isnt wrapped with the shield, and pin4 = receive or speaker complete
5 pin cobra=1-Audio 2- Shield 3-Receive 4-Switching Wire 5-Transmit, you can jump pins 4 and two
Dec 21, 2008 | Magnum 257 CB Radio
The marine cb radio turns on but you can't here noboby talking nor can u talk out from the cb
Sound like either an antenna problem, or a mic problem.
The mic on most cb's also serve as transmit/receive switching. A broken wire or bad switch in the mic or cord can cause either or both to fail.
If you have a bad antenna (or cable), you should still hear squelch noise on receive (maybe lower in volume) and be able key the mic and get a transmit light on the unit. Visually inspect the connector, cable and antenna. If need be use an swr meter to prove the antenna system is bad.
Hope that helped...
Geno
Aug 01, 2008 | Audio Players & Recorders
Radio Communications Logo
260 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
