Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Machine won't wash after using dryer.
My WD71 won't now wash cloths after a friend used the dryer. I never use the dryer and now when i put a wash in close door, add wash tab etc then select which wash i want everything ok up until i press the start button, it doesn't beep or do anything!!!! I'm not sure if i have to switch machine back to wash mode after drying clothes or whether the start button has broken??? I can't find my manual so anyone know where i can download one??? Please help.
  • Bealo Sep 10, 2007
    thanks for that, but there is nothing in the troubleshoot section regarding my problem.
    I have tried turning off the machine at the on off switch and at the mains for a couple of hours to try and reset it but still nothing.
    What do you suggest??????????????
    yes the door is firmly closed.
    yes when i select a programme it is displayed in the info bubble as normal.
    yes when i power off at the mains then switch it back on the on off switch is working as it should.
    i have just tried all of the above and gave the door a really firm shut selected programe c pressed the start button but still nothing, no beep or no machine start up.
  • 78 Answers
Manual here: http://tinyurl.com/35dh9v
Posted on Sep 10, 2007
  • Austin Walters
    Austin Walters Sep 10, 2007
    Make sure the door is firmly closed.
    When you select the desired wash does the info bubble "display screen" show the correct data.
    When you power off the machine at the mains and then switch it back on, does the front power(start) button start the machine up?
  • Austin Walters
    Austin Walters Sep 11, 2007
    It could be the circuit board behind the front panel.
    Does the Dryer work ok?
Wrinkles clothes terribly. Solutions.
Check your settings on your dryer. See if it's on a longer duration of time to dry. Dryers have different wording depending upon the make and model. If you're trying to dry smaller loads the heat settings s
does not have to be set for very long. Heavier, loads with thicker clothing will need to dry a little longer. When you take the clothes out of the washing machine, do you shake the clothes before putting them in the dryer? And do you use dryer sheets? Believe it or not, they're not only used to help make your clothe's smell fresh but they also help elevate static and a few wrinkles.
Mar 23, 2015 | Washing Machines
Hi We have a miele condensor dryer. It is working fine except that you have to put clothes through twice to dry. It seems to cut short the drying process and then you need to put the machine back on...
The first thing you need to check is your vent system. If your dryer vent is clogged with lint, the dryer has a hard time expelling the moisture.
Then, if the vent is clean, try using a timed drying cycle instead of a sensor cycle. If your clothes get dry using the timed cycle, then you might have a sensor problem.
Also, make sure your wash machine is properly spinning out the clothes. I saw that once before where the customer thought the problem was with the dryer, but it ended up being their wash machine's ATC switch adding water at the end of the spin cycle.
Nov 01, 2014 | Dryers
I have a Semi Automatic Whirlpool Sparkle washing machine my question is can i put water in the dryer just to remove soap from the clothes
Whether your dryer is electric or gas, DON'T PUT WATER IN THE DRYER!!! If you need to get more soap out of the laundry, run it through another cycle without soap.
Jul 27, 2014 | Whirlpool Washing Machines
Where do you put the fabric softener
In the dryer. Use dryer sheets - they're much more convenient and more direct. Clothing doesn't get stiff in the washing machine, it gets stiff in the dryer - treat it in the dryer, where it happens.
Better still, hang your clothing outdoors on a clothesline if you can - that's as good as it gets, and laundry CANNOT smell better than it does fresh off the clothesline.
Jul 25, 2014 | Kenmore Washing Machines
Is fading and shrinking my clothes
low temperature and low rpm of motor,must try this.
Feb 16, 2009 | Frigidaire FTF2140F Front Load Washer
Hotpoint Ultima WD71 - floods on drying programme
you may have a hose loose or holed at the inside rear of the machine.
Jan 04, 2009 | Hotpoint Ultima WD72 Front Load...
Wd71 with e30 code on display when i try to use the dryer
try changing the thermostat located on top of heater in top of machine
Nov 08, 2008 | Hotpoint Ultima WD72 Front Load...
Wd71 error 34
get a washboard and a jug
Feb 14, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
69 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
