Question about DFI LANPARTY UT ICFX3200 T2R/G Motherboard
Memory I have had problems when trying to install OCZ DDR2 PC2-6400 memory on my motherboard. This memory comes as two 1GB 800MHz modules, which seem to be within the motherboard specifications. I have checked the memory on a friends computer and it seems to work fine there. The computer is using windows vista which seems to be preventing me from using a Bios flash.
  • Mal3 Sep 13, 2007
    I apologise for the vagueness of my posted problem.
    There are four slots for memory, I have attempted installing the modules in all combinations but they still have the same result; the computer starts up normally and when it starts vista it either freezes on the loading screen or a blank screen or flashes the blue screen of death before restarting the computer. The computer works, vista included, when I use my previous two 512MB memory modules. The friend that tested the memory was using the same edition of vista as I am. I have tried updating vista as well.
    Problem Solver:
  • 6 Answers
Are there four slots to install memory?
Posted on Sep 11, 2007
SOURCE:
Will 2gb ddr2 800mhz ram support d102ggc2
No. The maximum system memory that can be installed in 2GB, that being two 1GB RAM modules, Also the board only support DDR2 400 or DDR2 533 RAM.
Jan 07, 2012 | Intel D102GGC2 Motherboard
I have an asus m2n mx (windsor) motherboard and an amd athlon x2 3600+ processor . . . i have a pair of 667mhz 512MB (total 1GB) ram and a pair of 800mhz 1GB (total 2GB). . grand total(3 GB) . . My problem...
The manual for your motherboard states:
For dual-channel memory configuration (2), you may:
• install identical DIMMs in all four sockets OR
• install an identical DIMM pair in DIMM_A1 and DIMM_B1 (yellow
sockets) and another identical DIMM pair in DIMM_A2 and
DIMM_B2 (black sockets)
* Always use identical DDR2 DIMM pairs for dual-channel model. For
optimum compatibility, we recommend that you obtain memory modules
from the same vendor.
Sep 11, 2011 | ASUS M2N-MX Motherboard
I have a 512 DDR2 (533 FSB) RAM in one of my slot in Intel D102GGC2 Mother board,can i put a 2 GB DDR2 ram in another slot.If yes then What FSB will match and what is the maximum capacity of ram per slot?
This motherboard will support maximum 2 GB of total system memory. so configuration is should be 1GB + 1GB or one 2GB in one slot. If you attempt to install 2GB + 512MB, this is unsupported. but you can try if might the system can read it or not. there is no serious problem for installing memory exceed than maximum system memory...
Memory supported is DDR2 533 Mhz and DDR2 400 MHz...(sometimes on the market DDR2 533 will described as module name PC2-4200 and DDR2 400 as PC2 3200)
Aug 10, 2011 | Intel D102GGC2 Motherboard
I have a HP dc7600 small form pentium4HT 3.4 GHZ with 1GB of Ram. What type of RAM do i need to max this machine out safely?
Memory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 4GB
Slots: 4
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
icon_note.gifAlthough the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.When using PC2-5300 parts the maximum memory is 2GB. When using PC2-4200 the maximum is 4GB.
Jul 30, 2011 | HP dc7600 Small Form Factor P4 640...
Will pc2-5300 memory work in emachines t5082?
Yes it will work
Maximum Memory: 2GB
Slots: 2
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 02, 2011 | E-Machines T5082 PC Desktop
I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Nov 16, 2010 | Intel D102GGC2 Motherboard
Can I use Kingston 1GB PC2-5300 667MHz DDR2
I would assume that specific module would work, although it is not found on the QVL list from ECS for 1GB.. Most Kingston memory is pretty good with compatibility... However, in some cases, some motherboards will have trouble with the type of RAM you put into it. I would try to follow the spec from ECS listed HERE.
In the worst case, most retail stores will allow you to return the module and exchange it for another one if it does not work in your system.
Hope this helps!
Thanks for using FixYa!
Jun 30, 2010 | EliteGroup ECS GeForce6100SM-M (1.0)...
800MHz Dual Channel RAM on Intel D945GNT
YES U CAN BUT IT WILL ONLY RUN AT 667MHz.RichardM69
Nov 30, 2008 | Intel Motherboard
Upgrading Ram
Make sure you have the RAM seated in slot #1, and that you do not have DDR RAM installed as well, as DDR2 with DDR RAM will not work. Also, make sure the RAM you bought is on the QVL (Qualified Vendors List) for that motherboard. I know I have had problems with ASUS motherboards and OCZ ram before.
QVL Found HERE
Sep 05, 2008 | ASUS P5VDC-MX Motherboard
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
Open Questions:
See all DFI LANPARTY UT ICFX3200 T2R/G Motherboard Questions
DFI LANPARTY UT ICFX3200 T2R/G Motherboard Logo
222 people viewed this question
Top DFI Computers & Internet Experts
Ekse
Thomas F. Schneider
Steve Frost
Steve Frost
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
