Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Formatting my WD external hardrive
Hi, i've just bought an WD hardrive and it was suggested that i format it since i'm running windows XP pro, but i wanted to know why i should do this and what the benefits would be?
  • kabe Apr 26, 2008
    what is the step by step instructions for formatting western digital my book essential edition 500 GB external hard drive????
My 250GB hard drive is full and I want to erase some files. How do I do that?
Posted on Jan 16, 2009
    Brigadier General:
  • 6,966 Answers
Hi, In computer terms, formatting a hardrive is the process of preparing/setting the different areas (for read/write) of the harddrive and keeping a list of the addresses. This way the computer would know what data went with what and to where in the HD. Most if not all new HDs are not formatted (prepared) for computer use but are detectable by the PC. Formatting not only makes the HD recognizable, it is now usable. By formatting, the PC also erases any and all references to the existing data on the HD. After being erased and prepared, it also checked for any possible errors. Hope this be of some idea/help. Good luck and kind regards.
Posted on Sep 10, 2007
SOURCE:
I've got a 2 TB WD Elements external hard drive, and suddenly, no computer wants to recognize it when I plug it in. It is just rejected by any pc i've tried (3 laptops so far...) and I've a...
Is the PC you've used before is the operating system is windows Xp? If you've using windows Xp before then you've plug it in a windows 7 Operating system, it means your hard disc have no problem the operating system of your PC is different than before. Try to plug it in a windows Xp operating system then recover it in there then format it in a windows 7 operating system then, the windows Xp and windows 7 try to make a network place in the connection then share the hard disc files that you've recovered then copy and paste it in the newly format hard drive that formated in a windows 7 operating system.
Jul 21, 2011 | Western Digital Elements 2 TB USB 2.0...
I WANT TO FORMAT MY DRIVE C BECAUSE I HAVE FILES IN MY DRIVE D. HOW? I AM USING XP PRO.
Hi, welcome to FixYa.
You cannot format your drive C: while windows is still running!
If you sure you are running your Windows not from drive C:, then try to format the drive C: from bootable Windows XP CD-ROM.
Mar 11, 2011 | Acer Computers & Internet
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Installing 1tb External Hardrive from Freeagent onto Macbook Pro
I would be tempted to format the drive using the disk utility whch can be found under applications and then utilities once opened choose your drive in the left hand window and on the right hand side click on erase. If you are using the Seagate drive for the Mac only, format it as a Mac OS Extended (journaled) Choose your volume format and name and then erase. Hope this helps.
Dec 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I can not open my WD passport (1000 GB) external drive
you can't open it because this is a cause of viruses in your hardrive and your drive is infected i have this problem 2 weeks ago and fix it. open it from my computer right click go to manage and go to disk management open your drive from your WD. delete unrecognize files and hidden files.
Jul 10, 2009 | Computers & Internet
Why cant I Format the hard drive on a dell pc
when the system is u and running normally the comp is using the hardrive to run your computer to format it you must enter the installation of xp and format the disk during the installation process. there is a part of the installation where if theres a o/s on a harddisk it will allow you to format it just make sure you format it to NTFS if will be one of the selections
Mar 25, 2009 | Dell OptiPlex GX260 PC Desktop
Can't open My WD Mybook Home edition 500 GB External Hardrive
sounds like the hard drive is failing... i suggest you find yourself a data recovery program soon
Jan 05, 2009 | Western Digital My Book Essential Edition...
Ibm thinkpad 2645 600e
if you got a windows xp cd then boot from it and format the drive then reinstall xp
Dec 09, 2008 | IBM ThinkPad 600E 2645 Notebook
I have two operating systems on my hard drive.
You can manually disconnect the IDE/SATA cable temporarily from your motherboard (the one with NT PRO & XP HOME), then you can cleanly install a Windows XP on your new Hardisk. And after installing, you can re-connect the other hardrive on your computer and format it under your NEW Windows XP, be sure to set the BIOS BOOTUP sequence that you boot on the right drive.
-mrsolution
Jun 11, 2008 | Gateway GT4022 PC Desktop
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
Nov 19, 2007 | Microsoft Windows 98 for PC
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
382 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
