Question about Sony PlayStation 2 (PS2) Console
My PS2 has become blank
Hi everybody, When I switch on the Power button of my PS2 console then nothing happens, everything's blank .... yet it worked two nights ago, I played FIFA 07 on it .... I checked the Adapter, its fine. Please suggest something .... Thank you.
  • 752 Answers
Does the power light turn from red to green?
Posted on Sep 10, 2007
  • 709 Answers
Hi Banerjen, You may have blown a fuse or two. Only way to find out is to open the console. You have one easy to identify Fuse on the power Supply board, it is a Glass with silver ends type fuse. If it blows you have a power supply problem. Which is probably due to lack of cooling or a buildup of dust that has come into contact with humidity. Clean the internal completely. The fuses on the motherboard are harder to find. The are small box shaped surface mount components, and each one with have a PS1 or PS2, type number next to it. If you are not comfortable working with this , the Playstation Clinic can help you. www.playstationclinic.com. I can repair it and try my best to keep the Labor Charge under $25, plus shipping. Shipping is between $8 and $12 depending on your preference of shipping. The return shipping cost is $10.60. I do not gouge on shipping. The $10.60 is USPS Priority Flat rate with $50 insurance added. i hope this helps you. Regards, Greg at the Playstation Clnic
Posted on Sep 12, 2007
Yeah the problem is kind a big.But all you need is the Hair Dryer yes you heard me.Then put it next to the ps2 and heat the backside and frontside.Why all this??The problem is in processor.He is malfunctioning due the konstant on and off.This is the worst problem on ps2.I had the same,and service told me it's best to buy new one than to fix old one. It works with Hair Dryer.LOL
My PS2 wont turn on
is either the power cord plugged in all the way in back of the system, or is the switch on the back turned to on. This may work for ps2 non slim.
Jun 10, 2013 | Sony PlayStation 2 (PS2) Console
The on/off switch won't turn on. i have power on (red light) switch clicks but no green light. i have taken lid off and white button seams on work but still no green light. i have even held down little...
This is one of three things. Unfortunately, it's difficult to determine which, unless you start replacing parts.
1. Bad switch. The switch doesn't usually go bad by itself, has the PS2 been dropped? Bumped? Anyone push the switch too hard? It's held in by solder on all 4 corners. If the solder becomes dislodged, the switch can fail.
2. Bad cable. This is rare unless someone opened the PS2 and removed/installed the cable a few times and frayed the internal wires.
3. Bad motherboard. Sometimes a power problem can develop, or the motherboard can short out. It's pretty rare, but I have seen it happen.
4. Bad AC adapter. Recent power surge? It's possible that the AC adapter is delivering enough voltage to power the standby light, but not enough to power the actual system on. You can easily check this by plugged your PS2 up on someone else's AC adapter or taking your AC adapter to someone else's PS2.
You can find parts at the following page:
http://store.richspsxparts.com/ve12s.html
Nov 09, 2009 | Sony PlayStation 2 Slimline Console
Unable to solve Blank screen
hmm confusing but try turning your ps3 off at the wall give it 5mins and try again if nothing happens try it on another tv
Sep 25, 2009 | Sony PlayStation® 3 (80GB) Console
Cant configure my PCSX2 emulator
Just follow the guide at this link
PCSX2.net - Guide
or u can get help from this link also...
X-Win 32 PC X Server
I hope this will help you.
Sep 22, 2009 | Sony PlayStation 2 (PS2) Console
My playstation 2 won't turn on at all
Can either be the power button(pretty common issue or a loose connector).Depend what kind of machine you have .PS2 have a common denominator...but actually the machine are different each other.The FAT one and the Slim one are totally different
Fabio
Dec 02, 2008 | Sony PlayStation 2 (PS2) Console
Wont start
check the fuse in the plug.
disconnect the mains cable from the console, then re-connect it.
make sure the power on off switch, at the back of the console is in the on position.
Mike @ Compurepair.
Feb 23, 2008 | Sony PlayStation 2 (PS2) Console
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
PS2 dic read help!!!
Hi Anishpp,
You have a great console, it just needs some tuning. The arm that moves the laser up and down the rails may have become clogged with lint. I usually clean it out and flex it to apply more pressure down on the worm gear.
Nov 04, 2007 | Sony PlayStation 2 (PS2) Console
PS3 locks up when I try to load a PS2 game
If you have a 40GB it has absolutely NO backwards compadability with PS2.
Oct 26, 2007 | Sony Playstation 3 (PS3) Console
Playstation 2 power button
Try pushing the eject button to see if the power button is faulty. If the PS2 is off and you press the eject button, it automatically turns the PS2 on and ejects the DVD tray.
Sep 08, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
57 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
