Question about Microsoft Office Standard for PC
Access 2003 Hi I have created a graph using ms access 2003. I need to show the datasheet. What i am struggling with is adding 2 grand total columns one running vertically and one horizantally and is there a way to automate the sum of those new columns
    Problem Solver:
  • 12 Answers
Hi smiths, Try adding a Label to the report in Design View. In the Properties, select the control source for this field. Insert one for your vertical and horizontal calculations as needed. Hope this helps. Regards DeltaC
Posted on Sep 13, 2007
How to invoke a ms.access using parser
To parse a Text field that contains two words separated by a comma, follow these steps:
  1. Open any existing database.
  2. Create a table with the following structure: Table: Parse2Words
    Field Name: Empl
    Data Type: Text
  3. View the Parse2Words table in Datasheet view and type the following three records in the Empl field: Smith, John
    Callahan, Laura
    Fuller, Andrew
  4. Create the following query based on the Parse2Words table: Query: QueryTest
    Field: FirstName: Right$([Empl],Len([Empl])- InStr(1,[Empl],",")-1)
    Show: True
    Field: LastName: Left$([Empl],InStr(1,[Empl],",")-1)
    Show: True
    NOTE: You can modify the QueryTest query to account for spaces between the two parts in the Empl field. For example, if the text in the Empl field is "Smith,John" without spaces, remove the -1 from the FirstName field expression.
  5. Run the query. Note that the QueryTest query separates the text in the Empl field into the two fields below: FirstName LastName
    John Smith
    Laura Callahan
    Andrew Fuller
Jan 08, 2011 | Microsoft Office Access 2003 (077-02871)...
Ms Access 2003
If Access is anything like Excel, you can put in one of the cells: =SUM(A1:A5) If I remember rightly. That will add all the values from A1 to A5 together and display it. Alternatively, you can do =SUM( and then select all the values you wish to add together with your mouse by dragging, or selecting individually by holding CTRL whilst individually selecting. Hope this helps, because I'm only going under the assumption that Access is similar to Excel. Either way, you will need to use a formula similar to the one I just showed you.
Sep 10, 2007 | Microsoft Office Standard for PC
Different between MS EXCEL & ACCESS
Hi. MS Excel is for spreadsheet. Very useful when creating accounting documents. MS Access is for database. Very useful when collecting data.
Please visit these links to learn more about the 2 applications:
Sep 03, 2010 | Microsoft Windows XP Media Center Edition...
I want to learn that how can i connect my HTML page with my DATABASE created in MS ACCESS so that i can fill my table in HTML page directly-
1. You can use Pages option in MS Access. The page in MS Access is the web page in MS Access which allows you to access database in MS Access database.
2. You can use MS Office Front Page application and use the Form builder and connect your database in that.
3. You can also use Google Apps Business Solution for this however the database will not remain in MS Access but will remain in Docs online.
4. You can use .net application developer for this as well but needs expertise in that.
Mar 09, 2010 | Microsoft Office Standard for PC
Hi all i want to launch a form when i click the data base file in MS access 2003 (the form is created inside the mdb file of access)
on MS Access 2003:
goto Tools Menu --> Startup --> select your form for "display form/page" dropdown
uncheck the "display database window checkbox and display status bar checkbox
Hope this helps.
Apr 01, 2009 | Microsoft Access 2003 for PC
Connectivity between HTML page and Ms-Access
Set MyConn = Server.CreateObject("ADODB.Connection")
MdbFilePath = Server.MapPath("sample.mdb")
MyConn.Open "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & MdbFilePath & ";"
SQL_query = "SELECT * FROM Friends"
Set RS = MyConn.Execute(SQL_query)
<LI><%=RS("Name")%>: <A HREF="<%=RS("Link")%>">Homepage</A>
Nov 11, 2008 | Microsoft Office Standard for PC
Creation of a dynamic web page
Okay, you can't do that with just Office 2003 professional. You'll need to install and configure the dotnet framework on your machine first, and then you could use infopath to create forms to work with, say, something like MS Sharepoint. You could use MS Frontpage to create an online form and link it with an Access database, but you will not need the dot net framework for that. It's easy and Frontpage is pretty intuitive.
Here are the basic instructions for using MS Frontpage:
You will also need webspace or a webhost that will support Microsoft ASP web hosting.
If you haven't done this before, it may be easier to get a professional do it for you, using either Microsoft or PHP/MySQL based technologies. It will certainly be time efficient.
Oct 18, 2008 | Microsoft Office 2003 Basic Edition...
Autonumber help in Ms Access 2003
You cannot store the E in the autonumber field, but you can make the data look that way. Therefore, use the following format for the Employee_Id column:
Aug 26, 2008 | Microsoft Office Access 2003 (077-02871)...
MS Access
Use a query:
SELECT "000" & [LastName] AS NewName
FROM MyTable
And export this query to the text file on your C: drive.
Jul 11, 2008 | Microsoft Office Access 2003 (077-02871)...
Connecting html form to Ms-access data base
If, as I suspect, this is for a web form, then it effectively can't be done on a "proper" web server. This is because you cannot install MS Office on an MS server OS (e.g. Server 2003). You need to use MS SQL Server or MySQL instead. If this is for very limited use (i.e. only a few clients at a time), you can use XP running IIS but this is really not a good idea. The sedurity implications don't bear thinking about :) Linking a web page to Access can probably be done using ASP (never even thought of trying it - anyone else here know for sure?) If you are using a Linux web server then it's totally out of the question. Use Webmin or PHPMySQL to set up a MySQL database & PHP to code the linkage between the page and the DB. There are plenty of tools out there that will automate this for you, some of them Open Source and therefore free to acquire.
Sep 26, 2007 | Microsoft Office Standard for PC
Microsoft Office Standard for PC Logo
94 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
