Question about Indesit W 123 Front Load Washer
Indesit 126 washer/dryer
We turn it on and the pump seems to kick in right away, sometimes water starts going in but the pump is still going and then the door lock light flashes along with the easy iron light for about 8 or 9 minutes and it doesnt do the wash cycle. sometimes if we leave it for a few days then try to use it again it will work perfectly for a couple of weeks then go back to not working again and lights flashing. this is driving me mad. the machine is less than 3 years old.
  • v_ob Sep 19, 2007
    Does anyone know what this particular error code means?
I have had the same problem. I thought it was the pressure switch as this is what the error code means - low or high pressure resulting in cut out. I too thought id fixed the problem but it has returned
Posted on Sep 16, 2007
I have an Indesit Washer/dryer (WIDL 126 S), and it is dot draining the water. I set in on drain or dry and nothing happens, it just fills with more water.
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump needs replaced.
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Washing Machines
Indesit WDL 126 dryer - at end of cycle not draining or spining
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Feb 11, 2011 | Indesit WA 125 Front Load Washer
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Wiring for Indesit Widl 126
Tell me, is the machine compleatly dead or what is it doing?
Sep 10, 2008 | Indesit WA 115 Front Load Washer
Indesit widl 126 s washer/dryer wont drain
Ive fixed my problem by turning it on, and after it does the standard pumping part pull out the power plug. Then when you plug it in again it will completely drain and its all reset again.
Aug 28, 2008 | Washing Machines
Indesit WIDL 126 washer/dryer
look at
Jul 06, 2008 | Computers & Internet
what u can check is the outlet hose does it go down a plastic pipe if so pull it up slightly until it stops a simple mistake if its gone down slightly too much what happens is if its low down the pump kicks in as it thinks the pipe is lower then the washer to drain it try it if i isnt this then it will more then likely be a faulty timer which u will have to replace m8 let me know how it goes m8
Dec 13, 2007 | Indesit WA 125 Front Load Washer
Indesit washer dryer
check heater element first, thats a common fault on these machines, loose connection or open circuit, after that check the pump for same open circuit
the rotating of the timer knob indicates a fault, maybe even a setting fault, to try and reset set to off, turn off and back on again, till light flashes, then turn off again and start again
if you do not know how to test for open circuit then the job is not for you, sorry
Oct 14, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
230 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
