Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Windows problem i am using windows 2003 server my destop flshing in 10-20 second what is the problem
  • 293 Answers
MEMORY PROBLEMS Hi, FOR LONG BEEPS, ONE SHORT BEEP IN AN ENDLESS LOOP, BLUE SCREEN OF DEATH AT STARTUP Try using Memtest 86+ to diagnose your memory problem. You can also try the following methods. Turn off power, Unplug. Remove the cover of your PC. Remove the memory from the Motherboard. Note on the locks! Clean the memory contacts with an eraser yes that's right a rubber Pencil eraser. It should be shiny gold. Reseat your memory to the motherboard and Test! ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Posted on Sep 20, 2007
Second hard disk drive not detecting
make sure you have the second hd set to slave
Jan 31, 2013 | Dell POWEREDGE 2900 Server
Hi , We are having 2 windows servers with identical configuration, and also we are using the windows 2003 with vendor application, We installed 8 GB of RAM in both server , But I could only 4 GB amount...
To reply your query in short. If you have any of the following versions of server it would support the maximum RAM upto 4 GB.
Windows Server 2003 R2 Standard Edition
Windows Server 2003, Standard Edition SP1
Windows Server 2003, Standard Edition SP2
Windows Storage Server 2003
Windows Small Business Server 2003
If you are using : Windows Server 2003, Web Edition
It will support only 2 GB of RAM
For your information to get a complete information about Memory Limits for Windows Releases. Please visit the following site:
If you find it useful please do not forget to rate this solution.
Jul 14, 2010 | Microsoft Windows Server 2003 Enterprise...
Hp ml350g4 p server hang on diagonestic screen, unable to set standard boot order(ilo)
To repair your installation of Windows, follow these steps:
1. Insert the Windows Server 2003 CD in the CD-ROM or DVD-ROM drive.
2. If the Windows CD displays the What would you like to do? menu, click Exit.
3. Turn off your computer, wait ten seconds, and then turn your computer back on.
4. If you are prompted to start your computer from the CD, do so.
Note You must be able to start your computer from the Windows Server 2003 CD-ROM to run Windows Setup. Your CD-ROM or DVD-ROM drive must be configured to do so. For information about how to configure your computer to start from the CD-ROM or DVD-ROM drive, see the documentation that is included with your computer, or contact your computer manufacturer.
5. After Setup starts, press ENTER to continue the setup process.
6. Press ENTER to select the option To set up Windows now, press ENTER. Do not select the Recovery Console option.
7. Press F8 to accept the licensing agreement.
Setup searches for previous installations of Windows.
* If Setup does not find a previous installation of Windows Server 2003, you might have a hardware failure.
Hardware failures are beyond the scope of this article. See a computer hardware specialist for more help or try the Hardware troubleshooter. For more information about the Hardware Troubleshooter, see the Windows Server 2003 Help topic "Using Troubleshooters."
* If Setup does find a previous installation of Windows Server 2003, you may receive the following message:
If one of the following Windows Server 2003 installations is damaged, setup can try to repair it. Use the up and down arrows to select an installation. To repair the selected installation, press R. To continue without repairing, press ESC.
Select the appropriate Windows Server 2003 operating system installation, and then press R to try to repair it.
* Follow the on-screen instructions to repair the installation.
o You might have to change the boot drive sequence in your BIOS settings to successfully start your computer from the Windows Server 2003 CD. Contact the manufacturer of your computer, or see your manufacturer's documentation, for more information.
o If you cannot start your computer from the Windows Server 2003 CD, you might have a CD-ROM or DVD-ROM drive failure or other hardware failure.
o After you repair your Windows Server 2003, you may be required to reactivate your copy of Windows Server 2003.
Jan 22, 2010 | HP Compaq ProLiant ML110 G4 Server
Windows 98 crashes while I am accessing a share from a server
The OS may not be compatible for Server 2003, The best thing that you can do here is to upgrade your operating system to Windows XP or Windows Vista for full compliant on Networking.
Jul 29, 2009 | Microsoft Windows 98 Second Edition OEM...
Cant configre printer sharing via web on win server 2003
Yes is possible. Use Routing and Remote Access facility from Windows 2003 server to create a VPN Server. Create a VPN connection to Windows server, and thus you get an IP address from windows 2003 server and you can use printer.
Jul 07, 2009 | Microsoft Windows Server 2003 R2...
This server direct not boot by windows cd....
and u any time install window u lose the all data....because they have scsi hard drive and configuring bydefault Raid 5 plz make backup before u start this prosiger.......Dell providing u lots of cd's check it this cd "installation and server management" bootable cd put this cd into your cd rom drive...and i am giving u link that how to complete install window in this server.
Sep 18, 2008 | Dell 2.8 GHz Second Processor for...
Internet connectio
Vista is 64 bit OS, server 2003 standard is 32 bit. Change Server 2003 to Server 2003 R to get compatible. See Microsoft website. May suggest Server 2008.
Good luck.
Feb 13, 2008 | Microsoft Windows Server 2003 Web Edition...
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
