Question about Microsoft Office Standard for PC
Ms Access 2003
Hi I have created a graph using ms access 2003. I need to show the datasheet. What i am struggling with is adding 2 grand total columns one running vertically and one horizantally and is there a way to automate the sum of those new columns
    Scholar:
  • 133 Answers
If Access is anything like Excel, you can put in one of the cells: =SUM(A1:A5) If I remember rightly. That will add all the values from A1 to A5 together and display it. Alternatively, you can do =SUM( and then select all the values you wish to add together with your mouse by dragging, or selecting individually by holding CTRL whilst individually selecting. Hope this helps, because I'm only going under the assumption that Access is similar to Excel. Either way, you will need to use a formula similar to the one I just showed you.
Posted on Sep 10, 2007
Create a program that will the salary, no of hours work, the deduction, total deduction and net pay.
The easiest way to do this is to use Excel spreadsheet.
This is what you need to do.
Create a label at the top of each column as detailed.
Add a employee to each row under Name of employee
Then against each employee add the data and the formula in the relevant cell under each column.
The first column - Name of the employee
2nd column - salary rate per hour
3rd column - hours worked
4th column - gross pay (formula = salary rate X hours worked)
5th column - tax deduction
6th column - other deductions
7th column - total deductions (formula = tax deduction + other deduction)
8th column - net pay (formula = gross pay - tax - total deductions)
At the last row you can include a total for Gross salary paid, total Tax collected etc.
Once you have setup this spread sheet make a copy of it and save it as a template.
You can then copy this template for each new financial year so you do not have to create a new one each year, you only need to make minor changes for new employees, rates of pay etc.
Another way to make a salary program is to use Access Database. You need more skills to do this, but it can provide greater reporting capabilities.
Mar 24, 2011 | Computers & Internet
How to invoke a ms.access using parser
To parse a Text field that contains two words separated by a comma, follow these steps:
  1. Open any existing database.
  2. Create a table with the following structure: Table: Parse2Words
    Field Name: Empl
    Data Type: Text
  3. View the Parse2Words table in Datasheet view and type the following three records in the Empl field: Smith, John
    Callahan, Laura
    Fuller, Andrew
  4. Create the following query based on the Parse2Words table: Query: QueryTest
    Field: FirstName: Right$([Empl],Len([Empl])- InStr(1,[Empl],",")-1)
    Show: True
    Field: LastName: Left$([Empl],InStr(1,[Empl],",")-1)
    Show: True
    NOTE: You can modify the QueryTest query to account for spaces between the two parts in the Empl field. For example, if the text in the Empl field is "Smith,John" without spaces, remove the -1 from the FirstName field expression.
  5. Run the query. Note that the QueryTest query separates the text in the Empl field into the two fields below: FirstName LastName
    John Smith
    Laura Callahan
    Andrew Fuller
Jan 08, 2011 | Microsoft Office Access 2003 (077-02871)...
Hi all i want to launch a form when i click the data base file in MS access 2003 (the form is created inside the mdb file of access)
hi,
on MS Access 2003:
goto Tools Menu --> Startup --> select your form for "display form/page" dropdown
uncheck the "display database window checkbox and display status bar checkbox
Hope this helps.
Thanks.
Apr 01, 2009 | Microsoft Access 2003 for PC
Related MS Excess 2003
Hi Esd,
I'm assuming you meant 'Excel' since 'SUM' is the command you're looking for.
If your totaling Column D for rows 5 through 35, this is what you would need in the cell your total would be:
=SUM(D5:D35)
Also, when in doubt, Click on the '=' (equal sign) in the formula bar for a list of functions and help using them.
Any problems? Click the Askme button near my name.
Thanks for using Fixya.
Mike
Dec 06, 2008 | Microsoft Computers & Internet
Excel support
Cool problem I use this to track stocks for the latest 5 days, 15 days and so on.
First I have a sheet that is titled "DataRecord" this has my individual data in columns and the days recorded in rows. This is a complete record or all recorded stock activity. This is where all the entrys are made in rows. I freeze window to make the column headings and the left most column(the date) always visible to prevent errors.
Next I have a sheet that is titled "L5DaysData' I have sevreral rows of data like avg, & what ever. and the latest 5 days data starts on line say 6. a typ. cell ='DataRecord'!B970
The next cell down has a value of ='DataRecord'!B971 and so and on until B974
My Graphs are built on these individual "L5 or 15 or 60 or90 day" sheets of data.
Next I make a macro that translates the last line of data down one row and deletes the row just above the earliest that I want to save on "L5DaysData" so it always shows only the latest 5 days of information.
All the information shown on that worksheet is the data for graphs or tables refering to the latest 5 days activity.
The graphs are automatically updated with the data each time the macro is run.
You can also use a formula to adjust the date column by adding a value of one to a specfic dated cell untill you reach Sat or Sun and add 3 or 2 to that date cell and translate that down a column and use a work sheet that records only the latest 3Mo. with macros that updates the information when you want it to.
Hope this helps.
Glad to be of assistance - please rate the solution I can learn from you. Thanks
Oct 24, 2008 | Microsoft Office 2003 Basic Edition...
Problem in MS ACCESS
you need to upgrade first your operating system.. the new version of office 2003, is no compatible to your windows 2k.
Dec 13, 2007 | Computers & Internet
Mail Merge Print Problem
Was a recipient address created in an Excel spreadsheet or a database? Data needs to be pulled from somehwere to be added to the envelope.
Dec 05, 2007 | Dell Latitude D800 Notebook
Graph plotting
Dear rachana, In MS word 2007 you can go to Insert then there are multiple graph patterns given in it, like column, pie and scatter chart. Just put your values in it and it click ok, you will get the chart on worksheet. Its that simple.
Please press fixya if that was helpful.
Nov 29, 2007 | Computers & Internet
Connecting html form to Ms-access data base
If, as I suspect, this is for a web form, then it effectively can't be done on a "proper" web server. This is because you cannot install MS Office on an MS server OS (e.g. Server 2003). You need to use MS SQL Server or MySQL instead. If this is for very limited use (i.e. only a few clients at a time), you can use XP running IIS but this is really not a good idea. The sedurity implications don't bear thinking about :) Linking a web page to Access can probably be done using ASP (never even thought of trying it - anyone else here know for sure?) If you are using a Linux web server then it's totally out of the question. Use Webmin or PHPMySQL to set up a MySQL database & PHP to code the linkage between the page and the DB. There are plenty of tools out there that will automate this for you, some of them Open Source and therefore free to acquire.
Sep 26, 2007 | Microsoft Office Standard for PC
Access 2003
Hi smiths, Try adding a Label to the report in Design View. In the Properties, select the control source for this field. Insert one for your vertical and horizontal calculations as needed. Hope this helps. Regards DeltaC
Sep 10, 2007 | Microsoft Office Standard for PC
Microsoft Office Standard for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
