Question about HP mp2220 Multimedia Projector
No OSD ,Buttons will not respond on top of unit. Hp logo is reversed on the display,will not except any input
Please how can I setup my AVR 155 Harman Kardon Ezset/eq setting up
I haven't been into amps or receivers for over a decade and bought one of these second hand, to say I was out of my depth is an understatement.
The abbreviation OSD was not particularly helpful in the instruction manual as I thought it would show on the small led display on the unit/amp but its actually for a TV screen. I ended up using only the yellow connector of a composite cable (yellow, red and white connectors) connecting it from the video out (no. 12 of reverse of unit) and making sure the TV was on the right input, in my case AV.
Once on the blue screen it told me what input it was currently on (same as displayed on amp). From here I just pressed the OSD button on the amp's remote control and navigated to the Ez setup using the black arrow buttons surrounding the (amp remotes) OK button. I tried pressing left and right to select the 5.1 setup I have, but it did nothing and seemed to recognise it was 5.1 (not 7.1) anyway. Hope this helps someone.
Oct 12, 2013 | Audio Players & Recorders
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
The sceen say`s osd lock out and also the menu screen for the monitor is stuck on . The menu,+,- and auto set buttons wont respond
OSD Lock-out — The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message “OSD Lock-out” appears for 10 seconds.
If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Mar 20, 2010 | HP RY117AA w2408 24" Widescreen LCD
Help me my system is OSD Lock give me the solution.
Option 1: OSD lock - all 4 buttons are locked except the "POWER"
button. Press and hold the "MENU" and ">" buttons for 3
seconds to lock the buttons. Repeat this step to unlock.
Option 2: OSD & Power button lock - all 5 buttons including the
"POWER" button are locked. Press and hold the "MENU"
and "<" buttons for 3 seconds to lock all 5 buttons. Repeat
Mar 06, 2010 | ViewSonic E70f 17" CRT Monitor
I used to get OSD on the TV with my receiver, but it has gone and I don't know what setting to do to get it back. It is a Pioneer VSX-917V-s/-K. Thanks
did you happen to change to cable connecting the Reciever to the TV to an HDMI?
please note that the OSD will not appear if you have connected using the HDMI output to your TV.
Use component, S-video or composite connections for system setup.
Dec 30, 2009 | Pioneer VSX-917V-K Receiver
Osd lockout? How do I get the on screen display unlocked?
OSD Lockout prevents changes being made to the monitor through the use of the front panel buttons. When the OSD is locked, pressing a button from front panel displays OSD Lock-out for about 10 seconds. You can quickly remove the OSD Lockout message by pressing a front panel button again. To unlock the OSD, press and hold the Menu button until the Main menu displays, about 10 seconds. To lock the OSD, press and hold the Menu button until an OSD-Lockout message displays, about 10 seconds.
Dec 03, 2009 | HP W1707 LCD Monitor
How do i do a full reset? I would like it back to factory settings.
Click on Start, All Programs and click HP My Display, Again Click HP My Display and than you can follow the on screen display to reset it.
Also you can use the front panel buttons
Power Turns the monitor on and to standby or sleep mode.
? NOTE: The power button is located on the top or front of the monitor depending on the model.
- Menu Opens, selects, or exits the OSD menu.
-Adjusts the volume level.
-Opens the Quick View menu to quickly adjust settings for gaming, video, photo, and text.
– Navigates backward through the OSD menu and decreases adjustment levels.
+ Navigates forward through the OSD menu and increases adjustment levels.
Auto Auto-adjusts the display
Select Enters the selected option.
Jul 30, 2009 | HP w1907 LCD Monitor
Sony bravia 22in.. osd ( top left) does not go off when external inputs are selected
Had the same problem on my Bravia KDL37P300 (europe model). Sony responded that I can use the i+ button on the remote to display or remove OSD ikons. It worked fine and very fast response from Sony support centre.
Best regards
TheSonyUser
Sep 28, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
OSD
If you have checked thru the owners manual and could not find anything helpful for getting the OSD working again, you may want to try this reset procedure at the end of this post and then try to get the OSD working again. The owners manual should give instructions on how to activate the OSD.
This reset procedure will clear all the setting you have made, so make sure you know how to put those settings back in again before doing this.
If you do see the video from what ever video device you have connected to the unit (DVD player ect. ) but you don't see the OSD when you enter into any setup menu, then this reset procedure may help fix that problem.
If you are not seeing any video from the video device connected to the unit, then you may just have the wrong setting for the output from the video out to the TV. These Denon's are very complicated receivers (which you must know, since you own this receiver), and an improper setting can be causing the problems you have.
Befor eyou do this, go thru the settings menu and look for a OSD setting and see if it is turned off. If so, turn it on. If you can not find anything for the OSD try using the set up on the display of the Denon instead of the remote.
Here is the reset procedure:
With the unit turned off, hold down these two buttons at the same time:
Pure direct + Direct
while holding those buttons down, then press the power button to turn on the unit. Keep holding those buttons down for at least 3 seconds after turing the unit on and the display should flash at about 1 second intervals. then you can let off the two buttons and the unit is reset back to the same settings as when it was new. You now will need to put all of your custom settings back in to the way you need them.
Jul 09, 2008 | Denon AVR-3805 Receiver
Open Questions:
HP mp2220 Multimedia Projector Logo
Clive
Clive
Ekse
Thomas F. Schneider
