Question about Car Audio & Video
CKO In-Car DVD Player Distortion (CKOMMP001)
Hello Everyone This is my problem I have a CKO In-Car DVD Player 1/2din which get distorted when I turn it up?I can?t turn the volume no more the (1 Bar) The car that I am using is a BMW Mini Cooper S I have the BMW upgrade Harman Kardon audio system, which has a powerful amp.. Because the DVD player has a amp and the head unit also has a amp?the is being amplified to many times in distorts. Can anyone suggestion something that I could use between the DVD player & the head unit to reduce the distortion maybe something that reduces the power of the DVD player out put so I could turn it up and get a better all round sound. Many Thanks David
  • C39KER Sep 10, 2007
    I will tray that one out and let you no if it works.....thanks for the information
  • 752 Answers
You need something called a "Line Output Converter". It will reduce the speaker level signal and is usually adjustable. Most car audio shops have them for about $20.
Posted on Sep 10, 2007
SOURCE:
Sound distortion with NAD T 514...
You are probably clipping in that midrange. Since the DVD player is fine and CD player is distorting: they are line level outputs, If you are running those through an equalizer- the equalizer should allow you add in a 10db attenuation.
If you are running them straight to the amp, The CD line level output should be about 1.5 volt peak to peak, it may be the line level input of your amp is only 1 volt and the DVD player simply has that level of output so does not clip..
Simply adding into the cable a 0.1 microfarad polyester capacitor for each channel should be enough attenuation to avoid clipping. The midrange is where you hear the most content in large part because that is the range that the human ear is most sensitive to. Which is why that portion clips. The DVD audio is actually recorded to the same specs as CD audio. You can confirm this by playing your CD disk in your DVD player. .
Sep 25, 2012 | Audio Players & Recorders
Color distortion when playing DVDs
If the player has other outputs try connecting the player to the tv using one of them, ie: use the A/V output instead of HDMI from the player. If the problem goes away there is something wrong with the input on the tv.
Mar 16, 2008 | Televison & Video
Colour distortion
Try a new video cable assembly..
Sounds like the other colors arent getting thru from the DVD player
Apr 20, 2010 | Philips DVP5990 DVD Player
Panasonic DMR E20 Produces a line of distortion along the bottom
Sounds like you see head switching from the tape. Most TV are over scanned enough to hide it.
Aug 30, 2009 | Panasonic DMR-E20 DVD Recorder
Loud distortion after pioneer DEH installed into my car
check your connections on the radio. check the ground wire. it is very common that the ground wire is to blame.
Apr 10, 2009 | Clarion DXZ545MP CD Player
We have a philips up-grader dvd player and get color distortion
I would try hooking something else up to your tv that is hdmi compatible. If your tv looks fine, then you know it would be the dvd player. If it's the dvd player, then I would suggest getting a different brand completely. I have had alot of bad experiences myself and other people as well when it comes to the philips brand
Apr 07, 2009 | Philips DVP3960
Directed 10.2 dvd
add a noise filter in the input voltage good luck sorry my write i'm mexican technichian from tijuana
May 03, 2008 | Directed OHD1021 Car Video Player
VIDEO DISTORTION
check some of your wirings.. make sure nothing is peeled off and touching any metal OR buy a car voltage regulator.
Apr 29, 2008 | Car Audio & Video
Distortion
maybe you have a wrong conecction of your component, many times, distortion is caused by noise from enginee
Dec 28, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
487 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
